best brand overload spring
Old 07-30-2004 | 07:55 AM
petei's Avatar
I like to install a set of overload spring but I wander which is the best brand .I got a 2003 2500 dodge
Old 07-30-2004 | 12:52 PM
Patrick Campbell's Avatar
I had hellwig helper springs. They sat on top of the stock spring. They were good but noisy. They also helped a little with sway... I ended up selling them for Timbrens.
Old 07-30-2004 | 10:36 PM
P.O.R.'s Avatar
timbrens.........i like mine,they can take alot of weight and also help with sway,easy to install,ride is a little stiff if you are just on them,then again these are heavy duty trucks........
www.truckspring.com
Old 08-02-2004 | 08:29 PM
richard's Avatar
Ever thought about a set of airbags?
They even help smooth the ride out when empty.
Just my .02
Rich
Old 08-03-2004 | 03:42 AM
SuperGewl's Avatar
Add a set of Firestone Ride-Rite Air Bags instead. They will help the ride and give you more control depending on the load.
Old 08-03-2004 | 05:25 AM
Casey Balvert's Avatar
Timbrens
Old 08-03-2004 | 07:43 AM
SuperGewl's Avatar
Casey how do you like that Pullrite NO Drill hitch???
I plan on getting one of those if I get a new truck
Old 08-03-2004 | 06:11 PM
I love that Pullrite. Really well made, solid and tough as nails. Would not own anything else.
Casey
Old 08-04-2004 | 07:16 PM
PumpDaddy's Avatar
I just installed a set of 5000# Airlift bags and compressor system on mine. The ride is better unloaded, and had about 6000# of pumps and parts in the bed on Monday, it rode just fine. Just remember after unloading, to bleed the system back done to 10-15 psi or it'll ride like a buck board. The Airlift system has the auto fill to maintian atleast 5 psi in bags, but you can adjust the valve for more. Total cost was about $350.00 or so.
Old 08-05-2004 | 04:50 AM
pappyman's Avatar
I like my Timbrens but I pull a trailer allot and because I got the 9000 lb set it rides ruff when unloaded since a ruff ride doesn't bother me thats OK
If you only pull a few times a year then Air Bags mite be a better idea they seem to ride better unloaded with reduced air pressure
The 3rd option is to pull your spring pack and have a spring shop add leafs and re-arc your springs
Robert373
08-20-2011 12:35 PM
braap736
02-18-2011 04:46 PM
ticki2
01-05-2011 11:16 AM
sdsaw
04-21-2007 11:52 PM
petei
07-28-2004 10:00 PM
Quick Reply: best brand overload spring
