B&W Hitch and Rear Fender Liners
Old 04-20-2007 | 09:31 PM
03WVJay's Avatar
I am getting ready to install rear fender liners in my truck. But, I have a B&W turnover ball gooseneck hitch installed. The rod that is pulled to release the ball for turning is blocked by the liner. I would like to know how others have handled this problem. I just can't bring myself to cut a notch in the fender liner. I bet someone here has a neat fix for this ???
Old 04-20-2007 | 09:40 PM
annabelle's Avatar
Holesaw or drill bit, and tread the handle through it. Or donate the liners to me.
Old 04-20-2007 | 11:01 PM
bgott's Avatar
I used a holesaw, 2" IIRC, and drilled a small hole below the big one to hold the handle in the open position. I can pull the handle with two fingers and it wouldn't be hard to cap the hole if I felt the need.
Old 04-20-2007 | 11:06 PM
annabelle's Avatar
Great idea about the smaller "holding" hole. I like it.
Old 04-21-2007 | 10:04 AM
Jeff in TD's Avatar
I posted on your duplicate thread.
I made the hole small, so I can barely reach in to pull it. Once pulled out and turned, the handle will be kind of resting on the outside of the liner.
It works pretty good. I drew a nice symetrical oval, then used a drill and a metal blade on a jigsaw. Do knock the corners off where you cut. It's amazing how much skin that plastic can scrape off if you don't.
Old 04-21-2007 | 08:19 PM
03WVJay's Avatar
I ended up making a new longer rod and running it through a 3/8" hole in the liner. You can see the picture in the duplicate thread in the 3rd Gen No Drivetrain Forum if you are interested. Thanks for the ideas guys.
stroker101
03-16-2009 09:38 AM
wanna2500
14
01-27-2009 07:42 AM
03WVJay
04-21-2007 09:33 PM
Fisherguy
04-13-2006 09:17 PM
wyosteve
03-26-2004 09:53 AM
Quick Reply: B&W Hitch and Rear Fender Liners
