Axle Wrap
Old 10-20-2006, 06:43 PM
XLR8R's Avatar
I'm thinking of making them out of 304 SS 1" 11ga square tubing, triangulated w/o gussets; I just can't decide if it's worth it to build them box-style, like individual space frames, so they'd have maximum torsional rigidity.
Why do the frame-mount bushings tear up like that? Just underbuilt? Heim joints give a freedom of movement in 2 axes, so what forces besides "pitch" act upon the ladder bars?
Old 10-20-2006, 10:48 PM
Trickflow's Avatar
does anyone make some that would fit on a 2wd 1 ton dually? I get the axle wrap in first and second with my 48' 3 car wedge when it is loaded up.
Old 10-20-2006, 11:56 PM
ptgarcia's Avatar
They don't hold up when the axle articulates. Tuck one wheel in the fender and let the other droop in a whole and you get a lot of twisting on a joint designed to "swing". Sooner or later the joint fails. The heim allows for swing and twist. Do you follow?
Old 10-21-2006, 08:22 PM
bigwheels94's Avatar
Will those Warrior 6200's fit on a long wheel base truck?I've found several venders that make them for short wheelbase rigs.This will be the 1st one to fit a long wheelbase if I'm not mistaken.
Codyboy
02-15-2007 04:03 PM
G1625S
05-16-2006 07:07 PM
SmokenRam
01-26-2006 11:22 AM
fireram
13
06-23-2005 05:36 AM
rharveysr
07-28-2004 06:29 PM
Quick Reply: Axle Wrap
