Anyone recommend changing shocks for towing?
Old 08-17-2005 | 11:51 PM
Beavermike's Avatar
I've got about 25,000 on my 04. So far I've done some minor hauling, and had my quad in the back a few times, other than that, the stock shocks seem ok. Next month I'll be hauling a trailer up to Northern Alberta. Depending on what trailer I haul, could be 5-7000 pounds, hopefully more coming back with Moose.
So any suggestions if the stock shocks are ok for medium towing, or should I look at changing them. If so, all 4 or just change the back out?
Old 08-18-2005 | 07:35 AM
mijpa's Avatar
I tow 11.5K. I put on rancho 9000's there adjustable, Now that i have them on it's night and day difference.
I hope this helps
Old 08-18-2005 | 07:39 AM
OUTDOORSMAN's Avatar
i dont have a problem with my stock shocks. been towing everyday since the truck was new.
good luck on your moose hunt. post a pic of your trip when you get back.
Old 08-19-2005 | 03:34 PM
Raminspeed's Avatar
I would consider an upgrade all the way around to Bilstein shocks.
Old 08-20-2005 | 06:34 AM
sherman's Avatar
Stock shocks are good to go,I pull a 6 horse tr. weighing in at 13000-14000 most of the time with no problems. Good luck on the moose hunt!Are you heading for the Peace River country?
Old 08-20-2005 | 01:10 PM
Beavermike's Avatar
Yep, going north of Manning AB. Great Moose country.. and bears...and wolves... lots of critters.
Old 08-22-2005 | 06:48 AM
sherman's Avatar
I spent a few winters back in the 70's around Rainbow Lake and High Level fracin Oil Wells.Good moose areas!
Old 08-22-2005 | 06:53 AM
sherman's Avatar
I spent a few winters back in the 70's fracin oil wells in the Rain bow Lake and Zama areas. good hunting!
Old 08-22-2005 | 11:33 PM
Fueling around's Avatar
OK older truck, but my stock shocks were worthless. I changed to KYB and the empty load is much better compared to stock.
I don't tow, I haul as in 2,500 lb of camper which adds much more vehicle load than a trailer. The KYBs are very good with the camper. In fact, the ride is better with the camper.
I live in salt zone and an adjustable shock is pretty worthless after a winter unless you regularily keep the ***** free. Never tried the in-cab adjustables.
Old 08-23-2005 | 08:25 PM
Hannibal's Avatar
Stock shocks aren't horrible but they're too soft to control axle oscillation. I put a set of Monroe Reflex on our Durango. It had axle bounce and oscillation real bad. The Reflexes took it all out. Then my buddy put a set on his '03 2500. Makes a big difference in empty ride. Towing our 10,040 lb 5th wheel, our rides good. But empty it will almost change direction on some bad roads or RR tracks. I'll be putting a set on mine soon. For $44 each, I like the Monroe Reflexes. It's ok if you like something else.
Old 08-23-2005 | 11:07 PM
No wiser words written.
Thank you
-John
Old 08-24-2005 | 12:11 PM
BMH95's Avatar
I would stear away from the Reflex shocks. Anything made by Monroe will last at most 25K miles. I put them on my Tahoe on a good friends advice. (Towed a lot with it) They were great for the first year, but they crapped out fast. I hate Monroe. My first Vette came with them on it, and I thought the ride was just that harsh until I put Bilstiens on it. I was amazed at how well a real shock handles. Bilstien gets my vote.
Old 08-24-2005 | 04:27 PM
BoomR's Avatar
Stock Shocks should do the trick just fine. I have stock shocks on my truck and pull a 9,000 lb fifth wheel and have had not problems. If you are going to be going on continual long hauls you may consider.
Good luck with the hunting and post your pics .....
Cheers.
Old 08-27-2005 | 12:53 AM
NHDiesel's Avatar
240K on the truck, and judging by the fact that all of the mounts still have the original finish on them (and the shocks are Mopar), all shocks are still original! I will be changing them as soon as I have a chance. Ride is fine, including towing, but the shields are rusted off and I know the shocks aren't far behind. Obviously the drivetrain on my truck wasn't abused as much as the interior!
Jim
kawi600
14
01-19-2010 02:01 PM
kawi600
04-23-2007 09:19 PM
D.Wiggs
31
02-06-2007 11:47 PM
texasredrider
07-13-2006 04:04 PM
AK RAM
29
03-11-2004 09:15 AM
Quick Reply: Anyone recommend changing shocks for towing?
