Aluminum or 'glass sides?
From: Eagle, Idaho. Please set your watch back 20 years when entering.
I'm shopping for a camp trailer and the one I'm currently partial to can be ordered with aluminum or fiberglass skin. What is the good, bad, and ugly about these two options?
Thanks!
100 Proof
Thanks!
100 Proof
Re:Aluminum or 'glass sides?
There are two types of glass, filon and gel coat. Filon is the cheaper but you can see the fibers in the finish, gel coat is the more expensive but nicer finish I like the gel coat!
KC
KC
I like the smooth aluminum they have on the H&R and others but the heat sure can make it look wavvy when its in the sun.
But I have the Cougar with the gel coat which I like so far. 8)
Hey RamlovingVet-
First of all, thanks for your service to our country and a big 10-4 on P.E.T.A.
What kind of a weight penalty is there on let's say a 25' trailer with glass?
100 Proof
100 Proof
When I was looking for a new trailer I noticed a big price penalty for the fiberglass units. The fifth wheels I was looking at ran about $1000.00 per foot, the fiberglass units were about $10,000 over that.
I've been told, but don't know if it is true, that the aluminum trailers are easier to repair, since you can remove and replace an entire panel. On fiberglass you would need to patch, sand, and paint.
[quote author=100 Proof link=board=11;threadid=18896;start=0#msg177370 date=1062011591]
Hey RamlovingVet-
100 Proof
[/quote]
On My Trlr its only a few hundered pounds..I would roughly say on a 25 footer 250 give or take
Hey RamlovingVet-
100 Proof
[/quote]
Gel coat fibreglass is the easiest to take care of and will not dent easily like the aluminum. Actually, fibreglass is rather easy to repair. A hole in fibreglass can be repaired so that you will not see it without tearing the whole side apart to put in new skin. Can't do that with aluminum. The vacuum bonded walls can be a PITT to repair if the damage is a little larger. The easiest are the framed walls with batt insulation inside.
Got my first glass sided about a month ago, I like the looks vs. an aluminum. You will pay a couple of grand more for a smaller 21' range and probably double that for larger trailers. Don't know for sure, I'd think the fiberglass has to be more rigid keeping the seal around windows and doors tighter. One question I have for anyone who would know or have an idea why, why not a fiberglass roof? It would have to be stong as the plywood and rubber. It would have to cut down on the "black streaks" somewhat. Wouldn't have to worry about tearing the rubber. ???
The 2002 Itasca motohome I sold had a fiberglass roof. Still got black streaks. It's the dirt that gets on the roof that runs down when the roof gets wet that causes the streaks.
