air bags with rear sway bar
The Hellwig swaybar is compatible with Firestone airbags and carli LT bags as well. Plenty of room for the Mag-Hytec as well. per Don Thuren's suggestion I went with the 1 5/8" standard for my popup. The Big Wig is thicker for hardsided camper guys. It doesn't interfere with the bags nor Mag-Hytec either. Spares up to 315-70-17 fit also.
Had some AirLift bags installed in mine. The brake lines were a big interference. Bags on an 06 need to be off center on the lower support flat bracket.
Looked at the Firestones. Were 80 dollars more than the airlifts. Run them at
40-50 psi when the fiver is on the hook. 2900 lbs pin weight.
Dave
Dave
I've got a hellwig sway bar, mag hytec diff cover, XDR class V receiver, pac brake air bags and a BFG ATKO 285/70/17 spare under mine.......and they all fit fine and don't bother each other.
Sway Bar and Air Bags
I installed Hellwig rear sway bar and Firestone air bags and now I get a push to the side when towing fifth wheel into a turn such as a off ramp. Has anyone else experienced this problem? Is there an adjustment I need to make or is it just the way it is ?
Thanks
Thanks
btoops
04-01-2012 08:47 PM
Robert373
04-03-2007 12:20 PM
