Air bag in side frame or out side?
check out www.summitracing.com
That EBay source is priced too high.
Where are you guys getting these from and about how much are you spending?.....
I hate ebay, but heres what I found:
http://cgi.ebay.com/ebaymotors/Fires...#ht_4446wt_904
http://www.truckspring.com/suspensio...CKUP&year=2005
http://www.xtremediesel.com/fireston...drill2299.aspx
http://www.suspensionconnection.com/...con/2299D.html
http://www.autoanything.com/suspensi...A4899A0A0.aspx
I didn't even think to look on Summit..
I'll be honest, I'm a cheapskate and $20 is $20, is there any reason to go with the Firestone over these guys kit, which is also available on Summit??
Seems the engineering on this wouldn't exactly be rocket science in this day/age, but I figured people here have used both, so either both would work or one would work.
Thanks for listing off those other sites, just assumed ebay'd be cheap, but I HATE ebay. Summit is cheaper too..
I had a 97 2wd and I used the airlift kit outside the frame - that's all there was then and it was great and had plenty of travel cuz I could choose where to drill. I have FS on my 03 inside the frame and had too little travel until I torched a little off the bottom bracket which put the bracket flat against the axle tube and gave them 3/4" more travel. I had to bend the left brake line a little but no biggie. Now they never bottom out on the bags. I left the center bolt out of the bottom of the bags so upward travel can't over stretch the bags. I also made an accumulator tank out of PVC. I used 3/8" air hose between the bags and the tank so the air can flow freely. That fixed the empty ride completely. It also made the loaded travel more progressive. Craig
If anyone is considering Airlift bags, I found these at Jegs for $235.99 http://www.jegs.com/i/Air+Lift/022/57295/10002/-1 (not including shipping and Tax) while looking for some other stuff. I was thinking about Firestone's but after a little more research, I might go with these instead.
I got the Firestone Ride Rites. Love them and they have an awesome product. Mounted to the axel. No drilling all simple hand tool instal. Took about an hour to do it all. Mounted the pump against the firewall under the hood, and the gauge and switch assembly near the right knee driver side.
OP -
if you have a choice (sounds like you do), then i would choose the setup that goes outside the framerail. this will probably give you a more stable ride as they will be a bit further apart (wider) from each other. it's a bit more work, but might be beneficial in the long run . . .
I had a 97 2wd and I used the airlift kit outside the frame - that's all there was then and it was great and had plenty of travel cuz I could choose where to drill. I have FS on my 03 inside the frame and had too little travel until I torched a little off the bottom bracket which put the bracket flat against the axle tube and gave them 3/4" more travel. I had to bend the left brake line a little but no biggie. NoIw they never bottom out on the bags. I left the center bolt out of the bottom of the bags so upward travel can't over stretch the bags. I also made an accumulator tank out of PVC. I used 3/8" air hose between the bags and the tank so the air can flow freely. That fixed the empty ride completely. It also made the loaded travel more progressive. Craig
pullin hard
08-04-2009 06:37 PM
riata_ag
12-20-2005 10:38 PM
