7 Pin Wiring Help Needed
Old 03-09-2008 | 05:31 PM
Equalizer 2's Avatar
I installed a Voyager controller and I had to install the 7 pin connector after market as I didn't get the factory 7 pin with it. I bought the wiring harness from Dodge and ran the "blue" wire for the electric brakes directly to the Voyager controller.
In upgrading I can't find the directions for the wiring harness install to connect using the Dodge/Prodigy wiring harness. All other wires are connected and I have power to the controller but do not have the "blue" wire connected.
Where does the "blue" wire connect under the hood to supply power to the electric brakes? I know I can tap into the blue wire at the trailer plug or wiring harness but want a neat, clean install.
Thanks for your help.
Old 03-10-2008 | 07:39 PM
RRAMctd's Avatar
i am pretty sure the blue wire goes from the controller right to the trailer. its the line that feeds the trailer brakes.
Old 03-10-2008 | 08:42 PM
CarlJensen's Avatar
Here is the wire colors for ya..
http://www.marksrv.com/wiring.htm
Old 03-10-2008 | 10:26 PM
Thanks guys. I found the information useful.
gsmopar
08-18-2009 11:10 AM
strean
09-13-2006 03:54 PM
rjjr
04-19-2006 11:46 AM
Crimedog
03-11-2004 01:54 PM
Stevenc
11-21-2003 09:05 AM
Quick Reply: 7 Pin Wiring Help Needed
