7 Pin plug wiring problem
Can anyone help me by sending a wire diagram or any information on wiring in a 7 pin plug on a 2007.5, I've got 8 wires a Brown, Red with blue stripe, White with green stripe, Light Green, Yellow, Green, and (2) Black wires.
Carl;
Could you check your trailer plug and see if it has 12v on the first terminal to the left of center looking at the plug with the lock clip at the top. If the color code is standard on trailers, black is 12v and white is ground. White would be the bottom right terminal on the plug.
I just put another male plug on the trailer after forgetting to unplug it before coming off the fifth wheel. Kinda pulled it side ways. I had a intermitten loss of braking on the trailer. I found it did pull the TB wire.
Your post was timely for me as I'm going to pull the bed female plug out and see if anythng is loose in there.
My trailer plug is Clockwise from center looking at it;
Green
Red
White Ground
Blue
Brown
Black 12V
Yellow Center Pin
Thanks
Dave
Green
Red
White Ground
Blue
Brown
Black 12V
Yellow Center Pin
Thanks
Dave
SkyHarborCowboy
10-17-2005 10:13 PM
SkyHarborCowboy
10-12-2005 06:01 PM
Stevenc
11-21-2003 09:05 AM
