5th Wheel Rails
Old 02-22-2008 | 06:57 AM
cwoflyboy's Avatar
5th Wheel Rails
I bought a used 2500 that has 5th wheels rails already in it. I don't see a brand anywhere on the rails. Previous owner is deceased. Anyway to determine what brand(s) of 5th wheels will mount up to this beast?
Old 02-22-2008 | 07:29 AM
Bill1374's Avatar
Most common would be Reese rails which will accept many hitches beside Resse. Probably won't accept B&W. Try an rv dealer parts guy. They're usually pretty friendly and will give you good info.
Bill
Old 02-22-2008 | 07:30 AM
crabbelle's Avatar
usually any fifth wheel with set in the rails minus the adjustable type
Old 02-22-2008 | 10:01 AM
Busboy's Avatar
Take a picture and post it here, some rails run fore and aft while some run across the box. A picture tells a thousand words!
dan239's Avatar
Describe the rails and someone can probably tell you what will fit them. Give as much information as you can.
Daniel
Old 03-13-2008 | 02:30 PM
cwoflyboy's Avatar
The rails run width wise in the bed. The rails are 43"X5.5". The rails are 22" apart (center to center). Each rail has 6 slots that are 1 11/16X .5".
I am trying to determine either what brand these are or what brand(s) of hitches will fit these rails.
Thanks.
Old 03-13-2008 | 02:34 PM
Vinceg99's Avatar
Yeah just double checked mine and they are the same they are typical 5th wheel rails they will take any standard 5th wheel like Reese, Curt, Husky, and ETC...
Old 03-14-2008 | 05:42 AM
cwoflyboy's Avatar
Thanks folks. This is a big help.
Take care.
cLAYH
12-01-2010 08:10 PM
CZSteve
11-24-2007 06:37 PM
Micaiahfied
07-11-2006 08:58 PM
sdscuba
01-11-2005 05:01 PM
10-29-2002 03:15 PM
Quick Reply: 5th Wheel Rails
