5th wheel pin or gooseneck ball bed position
I am trying to determine where to put the ball in the bed of my Dodge in relation to the rear axle. Information I researched shows anywhere from 6 to 2 inches in front of the center of the rear differential. I looked at two SRW Dodge Quad Cab 3500 long bed CTD powered trucks with 5th wheels in the bed while parked in parking lots without their trailer connected when I was holidaying in Phoenix and Tucson. The 5th wheel appature center was directly in line with the center stake pockets and center of the rear rims indicating it was over the axle center. The owner was not around and I could not talk with them, but I noticed the 5th was not a slider type.
When I had a 1969 and a 1976 Ford 3/4 ton pickup with a long bed the fifth wheel pin appature center was position directly over the rear axle. I had as much as 12 ton of hay on the tri-axle 24 ft flat deck trailer and never experience any instability problems.
Where do you Dodge owners with fivers or goosenecks position your tongue weight to bear in the bed? Thanks for the advise and information.
I installed a drop ball and cut the hole exactly where the manufacturer told me to. I should have took another look. My truck is 2wd dually and the ball is almost 6" ahead of rear axle centerline. I pull 15,000# and when I weight the truck the front axle weight is just a few hundred pounds from being overweight while rear has plenty more capacity. My 96 model club cab dually with V10 had the ball about 2" over center and it done great. I plan to move my hitch back about 2.25' inches to keep from having to completely murder my bed. The safety chain brackets will get basically shifted one hole leaving one old hole and the ball hole will be enlongated probably try to patch this and get Linex to repair liner. This stinks I should have double checked before drilling hole. I think you could run the ball further forward like 4-6' on 4wd truck with no problem but 2wd defenately should be 2-4" over center.
My 5er king pin is 1.5" to the rear of the rear axle....tow,s just fine.
The only reason I put it there is because of other holes drilled in the frame from airbag brackets that used to be on the truck. If I recall, the directions that came with the hitch (Reese) said from 1" behind to 2" forward....probably not what it said, but that's what comes to mind.
Anyway, I never really understood what difference a couple inches fore/aft of the rear axle center would make. What if you were towing a 10k bumper pull with 1,500k on the hitch ball? How would that be worse than a 14k goose/5er with a 2,500k pin weight 2 inches behind the axle?
I don't know.....for me it's one of those things I can't let myself think about too much. My truck works the way I set it up, and that's fine w/me
Weight Distribution
A ball position directly over the rear axle would cause no leverage problems whatsoever to the steering axle, but the rear tires could be overloaded if no portion of the load weight was shared by the front tires. On the other hand, the heavy diesel engine, front differential and Quad Cab are so heavy on the front tires that too much weight transfer forward is not desireable either.
Leon441 what type of hitch do you have? I bought the B&W Turnover Ball and it's way too far forward on my Dually. I believe it's made for SRW trucks pulling campers.
in installed my hitch in the new drw. of course followin g the manufacturers directions my pin sits about 1 inch to front of center of the rear axle
if you wind up in back of the axle you will lose some of the weight transfer to the front axle. an inch or two one way or the other won't hurt but too far in back of the axle will eventual cause an unstable ride.
unless you are trying to fab your own hitch the manufacturers brackets will put your hitch in the proper position for your truck
typically the turn over ***** sit further forward than a fiver king pin set up
i had both in my for 3/4 ton the turn over sat in front of the fiver rails
5th wheel vs gooseneck position
Originally Posted by rockhound
in installed my hitch in the new drw. of course following the manufacturers directions my pin sits about 1 inch to front of center of the rear axle
SkyHarborCowboy
10-17-2005 10:13 PM
