5th wheel hitch
5th wheel hitch
I have a B&W 5th wheel sitting in the shed and I am debating on installing it or not. My pickup is lifted and while i do not tow alot I would like to be able to Pull a 5th wheel trailer once in awhile. My concern is that I will not be able to pull a trailer that is not modified in some way to accomadate for the lift. Also, i do not want to harm the resale value by installing a 5th wheel hitch and not doing alot of towing? Would you recomend the install or just not pulling 5th wheel trailers?
I thought so. I use the same hitch when I pull my dad's 5th wheel. Comes right out, it's not a permanent type of install like the bolt in plate type hitches are.
Also, are you talking 5th wheel or goose neck hitch? The hitch itself sits flush. The 5th wheel "companion" just pops in.
Hey shaef, I just read that you also have Firestone airbags. But you list onboard air as well. I have the onboard compressor for the bags, but not other air. Is your onboard air also used for your bags? Looking for all the info you can give as I want to have useable unboard air.
