5th wheel & 4x4 3500 drw
I have a jaco quest 265b 5th wheel. I'm considering a 3500 drw 4x4. After reading some of the threads about the 4x4's being so high at the bedrails, I'm wondering if this will be possible to match up. I have a 3" adjustment in my shackles. Don't really want to flip axle's if I don't have to. I was wondering if there is anyone out there that has this same setup. WE do some boondocking, so the 4x4 would really be nice. Any suggestions or comments are welcomed. I have 53" from ground to bottom of 5er in front now.<br> Thanks <br> Wayne<br>
Re:5th wheel & 4x4 3500 drw
You should probably be alright. Just to be safe there is a TSB on this and you should be able to find that info at:<br><br>www.dodgeram.org
I have 99 3500 4 x 4 pulling 1989 35 foot Jayco Designer<br>Series. Yes I flipped the axles on the trailer to match<br>the height of the truck. Adding new sleepers (spring stops)<br>on the opposite side of the axle. Meaning the top side<br>and welding them in place allows axle to be flipped. It <br>raised the trailer 8". This would be your best bet.<br>Not sure what you are considering, but lowering truck<br>doesn't seem to be the option. Wayne Hope this helps
BAJA MAN
03-16-2014 11:09 AM
igotyourgoat
13
07-03-2007 04:05 PM
