3500 TRUE chassis/cab is coming - 12.5k gvwr, 6.7 cummins, etc.
Old 03-02-2006 | 02:44 PM
Patrick Campbell's Avatar
19000 lbs is within the door tag if you run a 25% pin weight. 12500 GVWR - 7000 lbs truck weight = 5500 lbs * 4 for 25% pin weight = 22000 lbs trailer. Of course if you put a 1000 lbs bed on there you will only be able to pull a 18000 lbs trailer staying within all weights.
Old 03-05-2006 | 05:18 AM
RickG's Avatar
Originally Posted by chaikwa
Sure, my old 93 one ton will 'handle' it, but it's not within the ratings on the door tag and therefore, not legal. I can get into enough trouble without going and looking for it!
Yep, and GM has had IFS for longer than that, and I don't want one of those either.
I'm just 'old-school' I guess. I like leaf springs, solid axles and real frame rails. If I'm gonna pay upwards of $40,000 for a truck, I'm gonna get what I want or I won't 'get'!
Just MY opinion!
chaikwa.
There are haulers that will tell you you can haul over 30,000 lbs. GCVW legally with proper weight distribution , tire ratings , trailer GVW , etc. . They are correct as far as DOT goes but have a serious wreck caused by some idiot 4 wheeler and his lawyer will have no problem convincing a jury you were grossly negligent exceeding the GCVWR of your truck .
Old 03-05-2006 | 07:20 AM
chaikwa's Avatar
My point exactly. And I've seen that happen.
chaikwa.
Old 03-05-2006 | 11:36 AM
FAY's Avatar
FAY
Originally Posted by iker42
I was waitin for a 4500
iker42, you have evaluated the new 2007 Dodge chassis cab Ram truck realistically. DC is just not getting with supplying a unit with a legal GVWR like GM and Ford have been providing in the medium truck range for decades.
Example: My 2005 Dodge 3500 SRW with a 35 gallon fuel tank has a GVWR of 9,900 lbs., while the new 2007 SRW chassis cab with the 52 gallon fuel tank has a GVWR of 10,200 lbs. The new truck only has a 300 lb. higher GVWR than a pickup, but the chassis cab's curb weight will be higher than the curb weight of my 3500 pickup, because, for one thing, it will carrying 17 gallons more diesel fuel. I do not know if the 6.7L engine and corresponding drive train components are heavier than those of my 5.9L drive train, nor how much heavier a deck is over a pickup box. When everything is taken into consideration, I know the 2007 chassis cab DRW unit will not nearly meet the legal GVWR requirements for towing heavy loaded gooseneck trailers with high tongue weights.
I would like to get a gn flat deck trailer that has a TW well over what a DRW chassis cab can handle legally. The 4500 should have larger wheels and tires, a factory installed internal engine retarder brake system and a manual transmission with more gears and closer ratios. DC said they gathered input from end-users in developing the 2007 Dodge chassis cab. They must have talked with RV towers and performance enthusiasts. Yes, the 6.7L has future potential to walk over the Duramax and the straight frame rails accomodate a deck nicely. The straight rails would also accomodate a moveable fifth wheel to place more or less weight on the front end of the truck. Nevertheless, the 2007 chassis cab GVWR is the same old drawback to legally hauling heavy loads that serious working users already have been hindered by for several years.
Old 03-05-2006 | 11:43 AM
RickG's Avatar
I think D/C is trying to keep Dodge from taking sales from the Freightliner FL . A 60-65 gallon fuel capacity would have been nice too . You wouldn't have to fill it all the time - just often enough to get free showers at the truckstops . A 50 gallon tank won't get a hotshotter or RV hauler a good legal day's run on one fillup either .
Old 03-06-2006 | 06:17 PM
BCB's Avatar
BCB
ME 2!!!
BUT there is still hope
http://www.thedieselgarage.com/forum...ad.php?t=10511
2nd page:
Originally Posted by barrowed time
The new 6.7 will be coming in july or august in a ram 4500 or 5500, will not be in the 3500 and 2500 untill 2008 model year. Yea big truck lovers dodge is coming out with even bigger than the 3500. Can't wait to see them
Old 03-06-2006 | 08:01 PM
Fronty Owner's Avatar
Im seeing this turning into an 08 Mega Cab with an 8' or more bed.
Old 03-06-2006 | 08:21 PM
DZLPWR's Avatar
chaikwa.
These trucks will pull anything all day long, but stopping it is a whole nother ball game. When some dope slams on the brakes in front of you because of a 1'x1' cardboard box in the road and your pullin 40k, do you think those brakes will do it? I dont think so, the brakes on these trucks are fair. Trailer brakes are okay but dont work but so well in most emergency conditions. Most people (not so much on this site) dont realize that they have to stop the load in a REASONABLE distance before they think they can pull it.
DieselRV
Competition / Pulls / OffRoad
0
07-16-2013 03:43 PM
Tree DR
12-01-2008 07:14 PM
OFFDUTYEXPEDITOR
10-03-2005 06:53 PM
Quick Reply: 3500 TRUE chassis/cab is coming - 12.5k gvwr, 6.7 cummins, etc.
