1998 2500 Ram towing pkg. wire color code.
Help! Does anyone know where I can find the Dodge factory wiring color code for my 1998 Diesel 2500 w/ towing package.
I have searched for hours and found several schematics but really nothing that matches the colors of the wires going to my 7 connector plug. The right and left Turn, running lights were easy to find but none of Dodge's wire colors match the accepted code ( brown, black,white, blue, yellow, green and red.)
Thanks
Thanks
Miles PH:
You missed the point of my request. I already have the brake controller installed I am trying to install a second 7 pin connector to mirror the factory connector at the bumper hitch so I can plug a fifth wheel electrical connector in the truck bed rather than run a wire all the way back to the bumper. The Pollak (brand) socket has standard 7-conductor color coding but Dodge uses non-standard color coding. Surely someone knows which color wire Dodge uses for which function back at the plug socket. ???
Kerley (01-25-2020)
Royal-
Dodge uses their own color coding for trailer wiring harnesses. The best way to figure out which wire is which is to buy a test light and figure them out yourself. Be sure to have pencil and paper ready to write them down.
-WhiteThunder
-WhiteThunder
Try this site. It should answer your question.
http://dodgeram.org/tech/mods/electric/trailer_wire.htm
Whitethunder:
I have tried the usual route of test light but still having problems with a couple of wire colors. Right and left turn were simple to find. Tail lights/running lights were a give me. I have a Dodge red wire that is always hot so I assume it is Battery charge but the Blue wire is hot also from the brake controller. I am assuming the Dodge back-up lights is the violet wire. The common ground (white) is something else because a meter shows conductivity with the other lights grounds making checking that way useless. I always hate to ASSUME anything because ASSUME can easily make an *** (of) U (and) ME. I don't know about you guys but I hate vehicle electrical problems. Thanks.
OK try this
CIRCUIT FUNCTION
1 12 gauge black GROUND
2 12 gauge light blue TRAILER ELECTRIC BRAKE OUTPUT
3 12 gauge black/orange TAIL LIGHT (Trailer Tow Relay in PDC)
4 12 gauge Red/Tan* FUSED B(+) (40A, Always Hot, F8 in PDC)
5 16 gauge dark green/red LEFT REAR TURN SIGNAL
6 16 gauge brown/pink RIGHT REAR TURN SIGNAL
7 16 gauge violet/black BACK-UP LAMP
CIRCUIT FUNCTION
Hmmmm...
Originally posted by Eskimo
any idea why the brake controller's output was putting out +12v?
The Voyager sends out a "trace signal" which is a minute 12v+ current going out the brake output wire, looking for a ground, to indicate a completed connection to the trailer's brakes. This can be tested by hooking the blue wire to the probe of a test light, with the other lead of the light going to ground. It needs a little resistance of the bulb to work.. my Fluke Multimeter did what it's supposed to...NOT load the circuit.
I pulled the thing out, thinking it was bad... Glad I didn't toss it!!!
I'm gonna test it tonight, and the LED should glow green when I do this...
Eskimo is right on. Most controllers send out a very low amperage 12VDC signal on the brake output (blue) wire (actually, no amperage if the trailer isn't connected or a meter hooked to the connector! ) If/when you connect the trailer, a very low amperage trace current flows through the blue wire, through the trailer brakes and to ground - this is what signals the controller that a trailer is connected and illuminates the "connected" LED on the controller.
Rusty
Rusty
1ATony
1A Auto
07-26-2013 09:58 AM
sheriffav8r
07-15-2010 04:26 PM
TPilaske
16
11-22-2002 08:15 PM
