Using Search
Using Search
I'm sure it's just me but I find the search feature somewaht difficult to use. I don't understand the min- max date thingy. If I leave the min at zero and type +30 days I get one result but if I change it to +60 days I get different results that does not include the results from the first search. Is it possible to search the entire archive?
Re:Using Search
This may not be the most correct answer but what I do is in the max days, I input 777 and in the display, I input 250. Seems to work for me anyway. W-a-a-a-a-a-y back when I was just a noobie, I asked Jack the same question and this is what I learned to do. So, if it ain't right, it's Jack's fault. See, that way, I'm not wholly wrong, I was just taught wrong. ;D ;D<br><br>~Dave
Re:Using Search
Nope, that's the way you do it. Also, the search results would be difference becasue other posts might have more relevence to what you're searching for.
Re:Using Search
[quote author=NWDave link=board=2;threadid=6853;start=0#64701 date=1036940984]<br>This may not be the most correct answer but what I do is in the max days, I input 777 and in the display, I input 250. Seems to work for me anyway. W-a-a-a-a-a-y back when I was just a noobie, I asked Jack the same question and this is what I learned to do. So, if it ain't right, it's Jack's fault. See, that way, I'm not wholly wrong, I was just taught wrong. ;D ;D<br><br>~Dave<br>[/quote]<br><br><br>Hmmmm... must be a left coast thing <br><br>Thanks guys. I'll give it a whirl. <br><br>Off to pollute my brain with more DTR info ;D
MRFD715
03-17-2010 10:14 AM
DieselBoy20
09-23-2008 06:51 PM
Joe T
07-09-2007 09:38 AM
Commatoze
03-19-2003 08:20 AM
