I'm probably doing something wrong - but search won't work.
DTR Founder
Sometimes it'll take a little while. Lots of data to go through. Especially for a term like "turbo" which is all over the place. I also have the db doing some extra heavy work today so that time is a little skewed. It should be faster now.
I just did an advanced search on "injector removal" in the 12V section and got sent back to the search page every time. I checked and unchecked to use child directories and exact matches on user with no luck.. ????
DTR Founder
I just did the same search, using the 12 valve section only. I did it from the advanced search page and only looked for about 6 months of results. The term I used was "Injector Removal". I received back over 100 results. Wish I could tell you guys why you're seeing this, but I have no clue since I haven't been able to reproduce this issue at all, from multiple computers, multiple browsers and from different networks.
Also keep in mind that you have to wait for at least 60 seconds in between searches. If you search once and keep on going and going, you'll always be taken right back before you've not been waiting long enough.
hutchman
09-04-2007 04:47 PM
