Free X-Power Plus Module from BD Power!
DTR and BD Power have teamed up to offer you 03-05 Dodge guys and gals chance to win a free X-Power Plus Module with Power Dial!
Turn and Burn! BD's new X-Power Plus Module with Power Dial
BD's new X-Power Plus module for the 2003-2005 Dodge-Cummins offers what no other electronic performance product can: State-of-the-art technology, serious power and ultimate control - all without compromise!
Unlike other products that raise fuel pressure to increase fuel delivery (which can cause leaks and damage to fuel system components), the X-Power Plus achieves performance gains by altering injector pulse duration and timing. By increasing pulse width, more fuel can be delivered at each combustion event - and by optimizing the timing (or the number of degrees before and after TDC that fuel is injected), combustion efficiency is significantly enhanced. Combine these attributes with cutting-edge fuel mapping, and you've got a product that not only delivers more power (from 50 hp up to 180 hp at the rear wheels!) but also lower EGT's, improved fuel economy, and smoother operation overall.
Supreme control is provided by the color-coded Power Dial, which is mounted in the cab. With a simple turn, the user is afforded progressive performance control in any one of three internally set power levels. Installation is easy - simply connect the X-Power's harness into the factory injector plugs and MAP sensor, and you're ready to enjoy new levels in performance.
We also offer a version that does duration only called our X Power Performance Module. It will give up to an additional 130hp through injection duration. This as well does not increase the fuel pressure.
Winner can specify whether they want the timing or no timing version.
Here are the rules;
1. You must be a member of Dieseltruckresource.com
2. You must own a 03-05 Cummins Powered Dodge
3. You MUST send an email to freestuff@dieseltruckresource.com
by 12 PM Eastern on 3/24/2007 with the following information;
A. DTR User Name
B. Name and address (Needed for shipping)
C. Phone number if you wish to be notified by phone if you win.
(Phone number is entirely optional)
D. One entry only per member (multiple registrations to increase entries will
be removed from the drawing)
Privacy note;
As always we do not sell or share your info with anyone, the winners info
will be retained for contact and shipping purposes ONLY. We value your
privacy just as much as you value your own.
This is a random drawing, all names will be placed in a large fishbowl (minus fish) and the winner will be drawn at random.
Hurry because the winner will be announced March 25th; right here!
Here are the rules;
A. DTR User Name
Privacy note;
With timing. The version without the timing advance would be used if you already have something that advances timing. I want the version with timing because I'm thinking about changing my configuration.
