Yahoo It's Here!!! Piers Super HX-55
Old 03-18-2003, 09:28 PM
drawson's Avatar
I got home a little late to nite(oldest Baseball game) and ther it was a box from PDR ;D 8)<br><br>I have check it out is all for now the thing has a huge intake housing. <br><br>It will go on tomorrow night. Power here we come I keep you all up to snuff on how it works....<br><br>Getting a box from Piers is just like Christmas morning all over again...
Old 03-18-2003, 11:21 PM
DarrellB's Avatar
Re:Yahoo It's Here!!! Piers Super HX-55
I was just getting ready to post and ask about the same thing. (scary) <br><br>Please let us know how it goes, I'm very interested in this turbo set up for my future Bombing plans. <br><br>What size is the exhaust housing? Does it use 4&quot; exhuast or does it require 5&quot;?<br><br>That thing has to be huge. 8)<br><br>DB
Old 03-19-2003, 03:30 PM
BigBlue's Avatar
Let us know man. I'm just as curious. May be an alternative to twins if it works good enough.
Old 03-19-2003, 05:00 PM
drawson's Avatar
It's on waiting for me to take her home or maybe I'll drive around alittle more tonite 8) 8) 8)<br><br>Piers has made this a truely bolt on turbo, all I had to do is rotate the intake housing about 5 deg. No messing with the oil return or the exhaust.<br><br>It has the 17 housing and bolts right up to the same down pipe the HX-40 did. ;D ;D ;D<br><br>I got to go out and see how she works now, but as far as putting it on it was a breeze.
Old 03-19-2003, 05:05 PM
BigBlue's Avatar
Sweet deal man.
Old 03-19-2003, 05:55 PM
Cummnzpowr's Avatar
Drawson: How much?$$ ???..inquiring minds want to know
Old 03-19-2003, 06:31 PM
DEZLPWR's Avatar
[quote author=Cummnzpowr link=board=7;threadid=12457;start=0#118141 date=1048118155]
[/quote]
Me too! ;D I am guessing $1500...
Old 03-19-2003, 08:28 PM
drawson's Avatar
It is on and the only words that come to mind is WOOOOOOW....<br><br>Piers has got another WINNER here!!!!! <br><br>It is truly a bolt on like his HX-40 no mods where need for the oil return or the exhaust matched up perfectly. The intake side had to be rotated down about 5 deg, although the elbow could have been turned in the hose.<br><br>Now for the good stuff....<br><br>It starts making boost at 1600 RPMs and once it comes on hang-on!!!! The boost takes off like a rocket(I'm going to suggest to Piers to call it the HX-55 Rocket) I am still in the break in phase right now but once tonite it hit 50 PSI at only 3/4 throttle.<br><br>EGTs cruising down the freeway(70MPH) are maybe 25 deg higher than the PDR HX-40 was this morning going to work. The boost cruising a freeway speeds is right at the same level as the PDR HX-40.<br><br>The EGTs seem to rise faster then stop and drop as the boost get higher. On the on ramp heading home tonite at only 3/4 throttle I entered the freeway at 3/4 throttle and only 1200 deg and 5 MPH faster than normal. At 3/4 throttle my seat of the pants meter tell me that there is more now than before at full throttle. <br><br>On the down side...<br><br>My top end smoke is gone the lazer cut delivery valve should solve this.<br><br>The rear tires are going to hate this turbo <br><br>Thank goodness for Piers giving us junkies the products that keep us in our evering ending quest for for more and more HP.<br><br>THANK YOU PIERS for another great product!!!!!
Old 03-19-2003, 08:29 PM
drawson's Avatar
Your right in the ball park price wise....
Old 03-19-2003, 10:01 PM
Jim Fulmer's Avatar
Drawson, we should have some kind of test between us as I will have my Twins with an 18.5 on the 35 and Lazer DV's and a Custom Plate with 370's, almost the same as you, I have 3.54's with 265 tires and the truck weight's 6300. My guess is the 50/55 is not going to be far from my Twins in H.P and EGT control, think about it. Chipsen's truck seemed close to mine now both in EGT's and H.P.<br><br>Jim<br><br>
Old 03-19-2003, 10:32 PM
DarrellB's Avatar
Sweet 8) 8)<br><br>That's a whole lot cheaper than a set of twins. <br><br>DB
Old 03-19-2003, 11:24 PM
drawson's Avatar
Jim sounds like a plan. There is one other thing, we do have different trans. Where are you HP wise right now before the twins? I have Dyno'd from 460-503 with the PRD HX-40.<br><br>
Old 03-20-2003, 11:17 AM
gunracer1's Avatar
and i just noticed, the uspsa and nra. i am a life member in both. have to write them [uspsa] and get moved down in class, i don't think i can handle master anymore. and a dodge diesel junkie also. just boys with there toys mike
Old 03-20-2003, 11:50 AM
drawson's Avatar
Mike you going to shoot nationals in Bend this year? I wish I could call USPSA and get moved to GM, I can't seem to shoot a classifier over 93% as of late.
Old 03-20-2003, 04:09 PM
gunracer1's Avatar
i may shoot the open, i work on sandy strayers shop stuff all the time. it sounded like a heck of a match last year. i haven't shot regular in 6 years. man what a thread high jack.
Quick Reply: Yahoo It's Here!!! Piers Super HX-55
