XZT+ Web Updates Page is Live
#286
I'm having issues. Computer took a dump yesterday and I had to reinstall XP and a billion updates. I'm having trouble getting the flasher to work. If I can't figure it out soon I'll give you guys a call.
#287
this appears to be it quad.........if mine has anything at all,its when i run it up to an rpm,then back off just a little..maybe a slight miss to it then.really subtle compared to before,maybe like a wheel weight thrown.but let me drive it a few days before i say for sure on that,,it may be a wheel weight thrown!ha!!.....the file seems pretty strong to me,it lights off quick,leaves a decent puff of smoke,trails a light gray trail of smoke for maybe 30 feet,then clears completely up.cruising in lock-up,if you roll into the pedal,it leaves a light gray trail for a few seconds,then clears right up....ill report back tomorrow after some more seat time......but you are definitely doing something right with this direction you went!!many thanks,,no other vendor would go half this distance to satisfy customers!!............bama
#288
Can't get the tune to load. The flasher on both my computers says unknown board detected, invalid serial number. I've had this problem before on some of these new tunes you've been sending. The regular ones from the website load fine, just something with these new tunes it doesn't like. I talked to one of your techs--they said you were da man and they'd relay the message.
I'll take the box to work tomorrow night and see if it works there. That's my only other option. My third computer at home has Vista.
#290
Who knew they would have wireless DSL in West Bum#&@%, Kentucky?
#291
after 300 miles on the new tune,,,,id say mine is 85%good...just a slight miss feel at cruising speed.i dont know what you did to this file quad,but if you can do 10-15% more of the same,mine would be perfect.......if thats possible..........whatever you changed,that was the problem for sure though.........bama
#292
Got it installed and went on a short trip @ 5 miles and didn't really get much over 50mph but it did seem to work. I was in 4th lockup at 50mph with 3lbs of boost and did feel some shudder but my rpms were 1200 so that could have been the torque converter (it's on the way out). If you send Bama a new tune, send it to me and I'll give a try.
#293
hamilton,,that same feel you got at 1200rpm,,,i get the same feel at about any rpm,as long as im just holding it steady at that particular rpm.not bad mind you,but nevertheless,,annoying...this is really close to being completely worked out though.......bama
#297
i know youre running wild with the adr.box stuff,tt,and high idle stuff now quad,,,,,are we done with this now?is that as good as we can get you think?...........this last file has us REAL close,but not quite perfect.this probably will cure most trucks out there i bet,but some are more stubborn than others i guess..............bama
