XZT+ replacing superchips
i currently have a superchip and am not very happy with it. would replacing it with the XZT+ be a smart move? or would it be better to just jump to a juice or comp box. or even a smarty.
ps trans mods are coming soon
Josh
Josh
Id probably go with the adrenline. I have the XZT+ and its great but know i am looking for a fuel only box for more power. So i probably should have just gone straight to the adrenline. Just my $.02
what is the difference does the XZT+ fueling and timing and the adrenaline just fueling? if the adrenaline is just fuel only couldnt you stack it with another programmer that does timing like a smarty. correct me if im wrong.
Thanks again
Thanks again
The Adrenaline is a TIMING and FUELING module.
XZT+ is timing and fueling (fuelling through the CAN BUS only @65hp)
Adrenaline is timing and fueling.........CAN BUS fueling through PL2.......PL3 and higher is fueling through the wire tap.
thanks for all the info guys. been doin alot of reading and im pretty set on the adrenaline. but one last question i plan on gettin the adrenaline and running some 150 injectors gettin air from a PS 62 or an SPS 62 which only leaves out my tranny. what all would i need done to it to support those mods safely. driving style-light towing, street and some track.
Thanks in advance
Thanks in advance
well i work at a dodge dealer and have an excellent trans guy. and i was hopin i could get away with a TC- VB- heavy duty clutches- and maybe a billet input shaft. i am on a tight budget. so that explains that.
Those mods would do just fine. You don't need a full tilt trans if ur not gonna be beatin on it a whole lot, granted, a full built trans would be good, but for what ur wantin to do, those afore-mentioned mods should do just fine.
sCreamin400
11-02-2008 01:46 PM
HOdiesel80
03-22-2007 12:19 PM
TEDHRS
03-03-2003 07:42 PM
