XZT+ and Commander
XZT+ and Commander
Bought them together, vendor said they would communicate with each other.
Before installing, double checked with Quad tech support, they said yes.
Didn't seem to work right, so I called Quad support again, and was told it would be a software update soon. But I found an archive on here from QZilla, saying they worked together. Is anyone using a Commander to change power levels on an XZT+? Don't want to drill a hole for the toggle if this will work, but don't like having the toggle wire wrapped around the shifter either. Not complaining, I know how hard they've been working on the new downloads, just wondering how this is working for anyone else.
thanks
thanks
The Commander works as is. The problem is that the wiring from the Commander to the XZT+ do not match up correct for the data port off of the XZT+.
We are waiting on some wiring adapters to solve this.
I'm using the switch till they get it worked out. You probably have this figured out or your truck may be different but on mine it was.
commander position 0 and 3 were fuel and timing
Commander position 1 and 2 were timing
no off position.
Hope this helps.
no off position.
Hope this helps.
Sixpack73
03-15-2007 02:10 PM
truk
01-09-2007 04:24 PM
truk
01-02-2007 07:33 AM
stock03
11-09-2006 11:27 PM
