XZT+ 3k Tune
Old 07-16-2009 | 12:12 PM
progrower's Avatar
XZT+ 3k Tune
I'm looking for the 3k tune for the XZT+ but cant find it on the quadzilla website. Anyone know were i can get it, or is it the same as the COMP tune.
Old 07-16-2009 | 02:49 PM
Dinner's Avatar
It is different than the COMP Tune and you can only get it by having someone email it to you. I'm sure some others will post up/send you a message about it.
Old 07-16-2009 | 05:40 PM
johnyb59's Avatar
pm me your email and I'll send it your way. idk what the difference between it and the comp tune are other than i know it fuels harder
Old 07-16-2009 | 05:52 PM
progrower's Avatar
PM sent. Thanks
Old 07-18-2009 | 11:24 AM
high bid's Avatar
Anyone have an issue w/the dload process? I keep getting an error.."the application failed to initialize." First I tried the beta1 tune and then just tried to reload the 3k tune...and still get the error. Any ideas...Quad is closed on Sat. Thanks.
Old 07-20-2009 | 03:36 PM
Stormin_Norman's Avatar
I could not get the beta1 tune to download either, ended up with the latest 2K tune
I mostly run in economy mode anyway
Old 07-20-2009 | 05:18 PM
high bid's Avatar
I contacted Quad today....going to try some system changes on my pc per their instructions. Man that would be great if it solved my random dead pedal issue
Old 07-20-2009 | 09:07 PM
high bid's Avatar
Ok, had to make a pc change. For all of those who've had issues w/the Quad XZT+ box being recognized by your pc, you may want to follow this Windows XP update.
1. Access control panel\system\hardware\device manager
2. Connect the XZT box.
3. After connection, you will notice the usb list expand.
4. Right click on the usb icon and select reinstall/update.
5. Select recommended updates and automatically install
6. When prompted for the file update location , type in "C:\windows\system32\drivers"
This should allow your PC to recognize the Quadzill XZT+ box. Hope this helps with this issue.
Blake Clark
21
08-21-2012 01:35 PM
johnyb59
08-12-2008 08:54 AM
highrpms
03-16-2008 09:35 PM
jivemother
01-24-2008 11:26 PM
