Xzillaraider for 98.5-2000 Trucks?
Old 07-15-2008 | 01:37 PM
Dinner's Avatar
Was reading up on the DTR Store and came across the Xzillaraider for 24 Valves from 98.5-2000. I thought the Xzillaraider was only for CR ISB's, or have they come out with one that hooks up like the XZT+?
Has anyone tried this on their VP 24 Valve?
Old 07-15-2008 | 01:52 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
I'm running an Xzillaraider stacked on a XZT+ on my 2000. Up intill this past year, Quadzilla made the Xzillaraider for 98.5 thru 02 2nd Gens. They dropped the box in favor of their new Adrenalene. Xzillaraiders can still be found at shops and stores selling the old stock. I also see quite a few on EBay.
Old 07-15-2008 | 02:53 PM
98.5Hotrod's Avatar
I ran one for quite awhile stacked with a Smarty, ran real strong. Sold it and got a TST PM3. Wish I had kept the Xzillaraider, Ran a little stronger and seemed to fuel higher into the rpm range.
Old 07-16-2008 | 02:05 AM
Dinner's Avatar
How do you go about stacking it with the XZT+? And also, do you HAVE to run the Commander screen thinger in order to get the full power out of the Xzillaraider?
Thanks!!
Old 07-16-2008 | 12:31 PM
JPR Ram's Avatar
Thanks!!
It's actually pretty easy. The only place where the two boxes "share" a sensor plug is at the MAP sensor. So from the MAP sensor (on the motor) I have the XZT+ plug, then from the other side of the XZT+, I have the Zxillaraider plugged, then the other side of the Xzillaraider the factory harness MAP plug. And no, you do not need the Commander. My xzillaraider has the control pod that kinda looks like the Recon; and I can turn on the highest setting just by a push button.
Old 07-16-2008 | 01:06 PM
Dinner's Avatar
Thanks JPR Sounds pretty easy! Maybe I'll get an xzillaraider in the next little while and try it out when I get my tranny rebuilt
usmcduncan001
09-14-2007 04:10 AM
ratat98
06-07-2007 01:19 PM
Rokcrlr
01-31-2007 06:23 PM
Tsutter
08-05-2006 07:19 AM
FireNhole
01-11-2003 06:56 PM
Quick Reply: Xzillaraider for 98.5-2000 Trucks?
