x-monitor question
x-monitor question
just got my x-monitor reading the instructions it appears they recomend post turbo, do not like that, it's to late to call bd any one know if pre turbo is ok. [undecided]
Re:x-monitor question
Guys, What do you think of the finish of the xmonitor compaired to the truck interior? Do they match fairly well? Are you planning to paint the Xmonitor to match? I was also wondering about the accuracy of the transmission temp sender. I was reading the install instructions on line and it looks like you tap into a wire from the computer? I am sorry for all the questions but I am considering one of these for my 02 and want to be sure I do it right. <br><br>Thanks
The only reason I could see them recommending post turbo is that in case you should accidentally damage the turbo installing it pre turbo on their recommendation, they don't want to be liable for it. I'd install it pre turbo. Just go slow and make sure you keep the drill bit greased up and when your done drilling, take a small magnet and run it around in there till you don't get any more shavings. Then keep the tap greased and when your done tapping, run the magnet through it again.
Im 6 speed so I got fuel instead of trans temp. I did paint mine to match and it blends in pretty well. The texture on the xmoniter doesnt match the pillar but it isnt clashy. The lines of the unit blend in very well and the display color matches the truck color and is adjustable for brightness. I did the pyro just as big blue said. I can send you a picture if you pm me your email address.
nitis
02-26-2007 07:38 PM
dditt0635004x4
11-09-2006 09:51 AM
4x4dually
14
08-11-2006 05:57 PM
