Would this work?
Would this work?
Ok, so as some of you know I have been trying to figure out a way to keep my autometer Lunar gauges in. I like the way they look and I have a lot of $$$ in them now. I know that the electric is not the way to go and 0-100 is way too high. I would also like a mechanical gauge but what I need (0-30 and mechanical) is not avail in Lunar series. I'd hate to have 1 gauge that doesn't match and it would be $$$ to swap them all out.
So, here's what I am wondering...
I have the old BOOST gauge that I had installed in my truck before. It is a 0-35 Lunar series...
So, if I take out the electric fuel pressure gauge and instal this but use one of these...
ISOLATOR
Would that work for me? I know it would not be labeled correctly but I'm not too worried about that.
ISOLATOR
Tell you what I would do. You're going to end up with 4 gauges in the end, right?
So, if one where not located right up next to the other three, it won't stick out like a sore thumb. Put the F/P (the one you already have) in a cubby pod. This way it's not so obvious that it's different.
(OR) find someone who has used the boost gauge as a F/P gauge with isolator like you said.
This is getting expensive!
(OR) Just run the 0-100, call it a day, chances are it'll be fine.
But, I really appreciate you taking the time to reply, Thank you!
tthomass
20
08-19-2005 09:35 PM
CaughtinmyGrill
29
01-23-2005 12:44 PM
LanceD
05-11-2004 07:55 PM
