would I need a different turbo
I want a efficient towing set up for my truck. After studying injectors and modules. I am set on getting edge EZ with mach 1.6 injectors. My question is whether my HY35/9cm set up can run this effieciently. I would like to hope so. I understand I will be around 315-325hp/625-650 tq. What do you think and would going to a PDR hx-35/12cm be a big benefit. Would I loose the lowend spooling I get with the 9cm set up. Thanks.
I did it on my 01 . i tow heavy and with the hy35 where i would run 1050 degrees i would run 900 with the hx35. It did seem that when i Got on it hard it would run up to 1250 real fast and then settle back down after it gained it's composure.
jhenson
09-08-2012 10:37 PM
Fisherguy
29
08-06-2009 12:45 PM
jjj_85
11-25-2007 01:41 PM
Dave88LX
12-08-2006 02:53 PM
