Would I get results from 4" exhaust
I found a smoking deal on 4" stainless steel exhaust and muffler for my truck. I am running original 3" pipe with muffler and cat removed, so straight threw. Would it make any difference on performance or fuel mileage to go to this new system?
Performance - NO!
Sound - Yes
And... with a 7 yr old exhaust and a "smoking deal".... it might be a good time to replace rusty parts and upgrade?
I have never subscribed to the reduced spoolup theory...but with a factory turbo... it's no biggy either way.
RJ
Sound - Yes
RJ
I don't understand! Why would the exhaust companies tell us that we'll gain 25hp, 50 ft-lbs of torque, and 4 mpg? They wouldn't intentionally mislead us, would they?
On that note, there are some really good deals on SS exhaust out there right now. I just ordered a 4" Magnaflow Pro Series SS system for $330 delivered off Ebay.
Definitely go with bigger exhaust as it will be better in long run when you do other upgrades, it will also lower your EGT's.
You would get that much with conjunction of other mods, air intake, chip, etc. It also has to be quality exhaust and same diameter all the way through, some of these exhausts advertise 4" but downpipe and muffler can be as narrow as 3"
I got tired of my straight-piped stock exhaust. Too loud for me. I'm going with the 4-inch to make room for future improvements. It's cheap, and it certainly can't hurt!
I like my ebay 5" exhaust. Its quieter than my old 4" from Summit Racing. I didn't notice any reduction in EGT's with either exhaust. In my experience with turbo cars a larger exhaust is always better. The whole "you need a little back pressure" argument that kind of works with naturally aspirated engines goes out the window with a turbo because the turbo itself creates a ton of back pressure. Your main objective is to make it as easy as possible for the exhaust to get out of the turbo and a bigger exhaust should do that.
John
John
I have done just the 4" on a number of 12 valve trucks and YES it will make a little difference going to the 4" and getting away from the 3 or 3 1/2 stock grap. I even had a 91 that I took the complete tail pipe off of my 03 truck and used and it along with a 4" straight pip and it helped it. You will get more by improving your air intake!
Its all bout flow:
1) bigger exhaust on a turbo vehicle is better due to more flow
2) the more air moviing in or out of the motor the better (thats y we buy turbos, intakes, exhaust manifolds and etc)
3) better air flow means more or the potential for more hp (which is where manufacturers get their ratings because their trucks may already have the simple bolt-ons like an intake or a programmer that typical consumer already has on their vehicle
4) more hp (especially with diesels) the less the engine has to work
5) the less the engine has to work the more mpg
Common
02-22-2009 06:01 PM
Tyler_02
02-28-2008 02:01 PM
PEAKSTRYDE
10-11-2007 04:20 PM
VikingDiesel
47
05-11-2007 12:52 AM
Hemlockusa
01-28-2006 07:07 AM
