Wiring a Westech FP gauge
Does anyone on here have the wiring hookup for the Westech Fuel Pressure gauge? I just rehooked mine yesterday, and it read 0. I guess my memory is not as good as in the past. I did use the grease hose trick I saw on RattlinRam's and Y-Knots, hoping this will save the sending unit. I ordered a new unit from Geno's Garage, it should be here Friday. I could sure use the wiring diagram if anyone has it. Thanks guys.
Terminal #2 goes to one side of the sender. Terminal #4 goes to 12v+ switched (hot with key). Terminal #5 goes to the other side of the sender and to ground. If you need a copy PM me your email and I will scan and send it to you.
HTH
Max
HTH
Max
wyododge
01-13-2009 03:25 AM
charcoal600
04-30-2005 03:34 PM
