wire tapped problems
![Unhappy](https://www.dieseltruckresource.com/forums/images/icons/icon9.gif)
tapped the pump wire yesterday. truck ran great yesterday. today it cuts in and out when you stomp on it (on level 5). ive got 2 codes showing up p1693 and p0253. what does all this mean. can nebody help please.
thanks, mooseman
thanks, mooseman
Check here for what the codes mean: http://www.obdii.com/codes.html
Tom
Tom
thanks guys for your replys. there is no smoke when it cuts in and out. since the wire was tapped there hasnt been much smoke on 5 set to highest response setting. could the wrong wire be tapped?
thanks, mooseman
thanks, mooseman
The P-1693 is a code to let you know a code was set in one of the other computers. It is known as a companion code.
P-0253---- Fuel Injection Pump Fuel Valve Open Circuit---Problem sensed with fuel circuit internal to fuel injection pump.
What kind of pressures are you seeing at the lift pump? The most important would be the pressure during WOT. It needs not to be less than 8psi.
P0216 is the kiss of death code for a VP44. Check all connections, dialectric grease em, and check ground. Also, did you go to fuse #17?
It is possible that you tapped the wrong pump wire, that is why I used a Blue Chip cover. HTH
i did use fuse 17 for power. does anyone know of a picture that points to the pump wire to be tapped. i had it done at the shop where i got my trans done. maybe he did tap the wrong wire. i cant seem to find a good pic. to double check the install.
thanks, no power mooseman in utah!
I already have my Comp box installed with the wire pierced but am skeptical as to if I am getting the performance that I should. Where can I get this Blue Chip Cover from. I used to get a considerable amount of smoke from my truck with the box, but then I threw away the stock lift pump and Banjo bolts and installed a high pressure fuel system, now I don't get sqwuat for smoke from it. The pressure guage never goes below 12 pounds no matter what I do.
It will be the 3rd item down.
http://www.bluechipdiesel.com/search...btnSearch.y=11
Originally posted by BigBlue
It punctures the plastic over the wire UNDERNEATH the cover.
