Wire Tapped Box Problems Need Input Quick
I am having problems with my Haisley Machine JVD Torque Enhancer. The box is flashing when it should be a solid color. And it is not making any power.
What kind of voltages should i be seeing with the key on and the engine off. Or should i check with the engine running?
The box taps into the injection pump and another wire by the injection pump. I am sure all tapped boxes would be about the same wiring.
I tried reconnecting my box and it seems like it is still doing it. I don't think i have a short but maybe a bad box altogether. Is there any way to verify for sure?
Thanks DTR
Thanks DTR
Never even heard of this box....
What type of connections did you make at the injection pump and others?? Many have reported issues when using posi-taps and the like. I soldered the connections for power, ground and pump tap on my TST Comp.
I was kind of dreading soldering these wires together. Because the injection pump wire is a pita to get to. I guess i will dedicate my afternoon to soldering and report back if that fixes my problem.
nope the box has been installed for quite some time now. It happened before but it was a loose connection. It like the box is getting power but something is wrong with the box. Oh well i am going to solder it up tonight and see for sure.
that cured my problem by soldering the connections. I need to pickup some of that liquid electrical tape. Never used it or seen it though.
I can't get no help from haisley machine.
Liquid Tape
I have talked to haisley about this box before. They told me that the reason the box is dis-continued is because of the after market box support that is out there. Like Edge,BD, etc.. Haisley are big in the machine department.
Glad that you found and fixed your issue... you should be able to pick up the liquid electrical tape at WalMart....
Liquid Tape
Liquid Tape
DieselDiehard
12-28-2005 06:33 PM
bws
04-03-2005 08:56 PM
TPilaske
16
11-22-2002 08:15 PM
