View Poll Results: Which is Better for a Wire Tap Box
Soldered connection
36.00%
Pump Cover Tap
64.00%
Voters: 25. You may not vote on this poll
Wire Tap Poll
Old 10-16-2007 | 08:44 AM
91rangerturbo's Avatar
Wire Tap Poll
Which is Better.. Since i have heard some mixed reviews about this. I would like to start a poll.
Tapping a wire with a soldered connection?
Or
Using a Stealth Wire Tap cover?
Old 10-16-2007 | 11:50 PM
JSPulliam21's Avatar
I think the cover would be better. The main reason is that the connection is sealed inside the pump, and is not subject to corrosion or the elements. Even though soldering the wire may provide a jim dandy connection it breaches the insulation on the IP wire and opens it up for corrosion to set in.
Old 10-17-2007 | 07:27 AM
that is when you cover the wire with liquid electrical tape and not have to worry about corrosion ever again.
Old 10-17-2007 | 08:20 AM
I did not know about the liquid tape. Is it like a rubber paint that you daub on the wire?
Old 10-17-2007 | 08:23 AM
pretty much.
click the link below
Liquid Tape
Old 10-17-2007 | 09:54 AM
Buckshotmckee's Avatar
Pump cover. When I tapped my 02 I didn't know about the cover and I just used one of those blue splice connectors (I'm brain farting on what there called).
LovinTheTorque
09-14-2013 01:02 PM
glarior
05-17-2011 08:46 PM
Hoss
04-12-2006 12:37 AM
bgilbert
03-02-2006 05:01 PM
TPilaske
16
11-22-2002 09:15 PM
Quick Reply: Wire Tap Poll
