which wire to tap
which wire to tap
I am installing my edge comp. I have pulled off the intake and got down to the wires. There are 4 wires feeding into the pump. What wire is the one you tap? There are 2 in front together and 2 behind it by the engine block, which one do you tap??
Take off the APPS housing (3 13mm bolts), remove the 5 torx screws on the vp44 (you need a special torx bit, Blue Chip or BD will have them), put the new cover on, tighten the screw down until resistance is felt and then tighten 3 more turns, hook up red wire from cover to grey wire on comp, replace APPS housing, go for a drive. They cost about $50 and then $10 for the bit.
If you use the scotchlock provided with the box make sure it is connected good or you will drive around for a month thinking you had the wire tapped but really didnt. Was really happy when I found that out.
Originally Posted by jeeptjstud
What do you have to do to put the vp cover on? Where do I get one? bout how much $$??
Is simple as hell! they are $50 and literally took me 10 min to install. They make a very simple and clean connection. I highly recomend it.
LovinTheTorque
09-14-2013 12:02 PM
glarior
05-17-2011 07:46 PM
WJB
10-03-2004 11:01 AM
TPilaske
16
11-22-2002 08:15 PM
