Which wire for my FP gauge?
OK, I installed my FP gauge but I'm not sure which wire to tap into to illuminate it. I need 12v positive which is switched to the dash lights.
Can anyone tell me where to look for that wire and the color code of it. Thanks
Why mess with the wiring and headlight switch. Locate the fuse and get a fuse tap, it pushes in with the fuse then you use a female slide connector and you're done. Of course locating the correct fuse is helpful. My 99 uses #5 "ILLUM" if that's not it then the other one that's tapped is named "CULSTER" Sorry forget which number it is, maybe 12?.
Update for correct wire: First removed dash bezel (held in place with spring loaded clips & one screw in upper right corner). Three screws holding down headlight/dimmer switch, Pulled out switch (wires plenty long enough). 12v test light, found two usable wires (black w/yellow stripe or solid tan). Turns out my alarm guy already has tapped into the bl/y wire. Trace the wire to the alarm module which is close to the FP gauge. New butt connector and I am illuminated. Pretty easy if you know where to look. Thanks you all
dodgestang
11-04-2007 02:29 PM
WJB
10-03-2004 12:01 PM
TPilaske
16
11-22-2002 09:15 PM
