Will they 37's fit?
Will 37's fit?
I have a 98 2500. I am looking for a new wheel tire combo. I was thinking a 3in susp lift, 18x9.5 Eagle 102 wheels, and 37x13.5x18 Nitto Mud Grapplers. Do you think 37's will clear with a 3 in lift? I don't have a problem chopping the fenders off. Has anyone done this? Let's see some pics. Thanks
it depends on the wheel offset. i run 37s with 4.5" lift and have NEVER rubbed. I don't off-road too hard, and my Weld wheels are 17x8 with 4.625" backspace (real close to a zero offset according to Weld). I am planning 37/1250/18 next, and i will go with an 18x9.5 wheel with at least 5" backspace. I'll add a couple pics to my gallery when i get home tonight.
35"s are the point of diminishing returns.
Besides, what does a 37 do that a 35 can't, other than cost more and make your truck setup a lot more complicated?
35s are what I would do for sure.
i have a 5" with 35's. i think with cutting you could do it. but if you go with 37's you are going to want to think about new gears. i have 3.55's in mine, that's why i didn't go 37's. it would make my truck get behind the power curve as far as fuel mileage, right now i'm at about 1800 rpm going 70. but if you don't care about that then go for it.
Originally Posted by timbeaux38
I run 35's with no lift...yes they scrub on the lower control arms at full lock. Not bad though. and I would much rather see tires stuffed than a truck with a lift and puny tires..
hey, IT'S JUST MY OPINION!!
no one said it had to make sense to anyone else!
I have 3.54 gears and 37s, tow heavy in 5th gear 60mph = 2000rpm. i even get 434hp/1006lbs torque with this combo! I will probably go to 4.10 and 35s in my next go-round, but only because i want to upgrade to a bigger 5th wheel toy hauler.
ok, check my gallery. once the photo gets approved it'll be there...DOH!
justramit
44
03-07-2007 10:21 PM
