Will these rims work?
They are rims off a military H1.
Dems; 16.5" with 8 lugs on 6.5 spacing.
8.24" wide with 7.25 backspace
Not sure of center hole dia.
Not sure of offset distance.
Thanks .... Ken
Thanks .... Ken
Darn
I can't try them on, I'm in Montana and they are in Texas. I did a search before posting. There is a ton of info about H2 rims and how to use them but none that I could find on H1 rims. More help please ... Ken
Anybody know?
This is more of a bump then anything else, but doesn't anyone know? Will H1 Hummer wheels work on a 96 4x4? The dimensions are in the 1st post.
Thanks ... Ken
Thanks ... Ken
I am running H2 rims with no mods with 315s. They rub on the mud flaps at full lock but other then that they are ok. I know you are asking about H1 rims but I thought if you knew for sure that the H2 ones work you could google to see if they interchange with each other on the GM products.
-Matt
-Matt
I seriously doubt it... those wheels have a tremendous amount of backspacing.. You could probably use some ~3" bolt-on spacers and run them, but then you might as well just buy normal wheels.
Mark Hodowanec
15
11-11-2004 08:50 AM
