Will Stacks Work With A Muffler
Old 05-15-2005 | 07:02 PM
99 cummins's Avatar
Is there room under an extended cab truck to install a muffler with stacks or do they have to be srtaight piped. I would like to use a single stack but don't think I could put up with the sound levels when traveling with a straight pipe.
Old 05-15-2005 | 07:13 PM
jiMMyCTD's Avatar
time to upgrade the stereo
Old 05-15-2005 | 07:36 PM
fearthedeere's Avatar
IMO puttin a muffler on stacks defeats the purpose of stacks. Thats just my 2 cents. And if sound is the reason just get some dynomat or whatever its called to muffle the sound.
Old 05-15-2005 | 07:50 PM
Cummins4Life's Avatar
Magnaflow makes a short little 14" muffler that would probably fit......but come'on, its a stack.
If you do the single, post some pics I want to do one sometime.
Old 05-15-2005 | 08:21 PM
bmoeller's Avatar
I had a severe drone. Put on a short Dynaflex resonator. It took the edge off, and made the sound deeper. Sounds great.
Old 05-15-2005 | 08:53 PM
99 cummins's Avatar
Thats all I want is something to take off the edge. To many neighbors for the straights
Old 05-15-2005 | 08:58 PM
99 cummins's Avatar
We were over at Lima Ohio during the 4 Wheel Jamboree this last weekend and in my truly humble opinion although the straight stacks with smoke rollin out as you drive looks cool, while your around the general public like that your just turning popular opinion against us. Does nothing but prove to grandma grunt that we really are the cause of noise and air pollution and just hastens tightened smog control laws. Right place, right time, but not on the roadways around the general public.
Old 05-15-2005 | 09:56 PM
SuperDave4x4's Avatar
Ah forget the neighbors..hehe...my straight pipe isn't loud enough.....
Old 05-15-2005 | 10:32 PM
TxDiesel007's Avatar
Just stay offa it till u clear the neighborhood.... Why stack if you are gonna muffle? JOhn Rodriguez has a magnaflow and his truck sounds wicked.. he wil chip in soon...
Tx
Old 05-15-2005 | 10:36 PM
Got Smoke?'s Avatar
Check your PM's.
Old 05-16-2005 | 01:17 AM
John Rodriguez's Avatar
Tire Hater
Actually, I HAD a magnaflow. I tried the 24" magnaflow and the 12" magnaflow. I ended up doing it a 3rd time and straight piped it. There is more than enough room underneath a qcsb. Hell, there's a good 4-5 feet from the downpipe to the back of the bed.
Old 05-16-2005 | 07:05 AM
Tire Hater
Also, while dropping the muffler made it sound WAY better IMO, 4.10s and 265/70's at 80mph for a 300 mile roundtrip still has my ears ringing
The majority of my system is 5", and I do get some drone inside, but outside it sounds **** good. I had my friend drive my truck for me, including a 20psi 4wd launch, and it sounds **** mean. That and a 20mph cruise-to-wot transition, and holy, seeing a huge truck light 'em up while roling is truely a humbling experience. I've never seen it from the outside, but DAYUM.
Old 05-16-2005 | 07:39 AM
Pike's Avatar
Well said "99 Cummins."
Old 05-16-2005 | 03:35 PM
Bobcat698's Avatar
You may want to consider an Aeroturbine muffler. They take the Edge off and sound great to boot.
I put a 5" T5050L aeroturbine on my truck after I got pulled over twice. No more problems from the police since then.
I'd reccomend the 4040L with resonator if you have 4" or the 5050L with resonator if you have 5"
Old 05-16-2005 | 05:38 PM
Forrest Nearing's Avatar
a stack or stacks are quieter to the neighbors than regular old straight pipe...
but there is PLENTY of room on an extended cab... I had a ~30" muffler on my single cab with stacks... resonated worse inside than it did w/ no muffler, so I just ran straight stacks. screw the neighbors...
Forrest
Quick Reply: Will Stacks Work With A Muffler
