Will OEM Lift Pump Fit in A Carter Pusher Pump Bracket?
I had a Carter pusher pump hooked up at one time. I still have the bracket mounted just in front of the tank. Will the stock lift pump fit in that bracket? It looks like it should. It has the same three studs coming out of the top of the pump. Thanks
Eric
Eric
