WIll I need a turbo upgrade?
Old 04-12-2003 | 10:06 PM
jrs's Avatar
jrs
I plan on installing a multi- level TST box with remote. Will my stock turbo provide a sufficient volume of air at high levels?
Old 04-12-2003 | 11:39 PM
PourinDiesel's Avatar
Re:WIll I need a turbo upgrade?
Yes.<br>But, if you want to go bigger injectors in the future, I suggest a bigger turbine housing with your HX35.<br><br>If you want even safer EGT's, you will need a bigger turbo.<br><br><br>--Justin
Old 04-13-2003 | 02:55 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=jrs link=board=7;threadid=13539;start=0#127472 date=1050199595]<br>I plan on installing a multi- level TST box with remote. Will my stock turbo provide a sufficient volume of air at high levels?<br>[/quote]<br><br>With the 275s, you're running ragged edge, if not a hair over. Check your temps after install, and if you see them too hot, toss the stocker airbox and find yourself a good air system. That should bring you on down into safe temps. If you step over to bigger injectors, then you'll definitely find yourself looking at new turbos.<br><br>Rod
Old 04-13-2003 | 08:12 AM
tlea7's Avatar
jrs,<br>With your auto you should have the HY35, not the HX35. I went the same way as you, started with 275's and EZ and then changed to BD2's and comp. Now I have a HX35/14 cm housing. The HY 35 is more than sufficient for what you are planning to do, actually I think the HY spooled up quicker than the HX does. The reason I changed over was not performance but EGT's. With the HY's 9cm housing it was easy to push over 1300 after 4-5 seconds of hard throttle(comp on 3). Now with the HX/14cm the EGT's are more under control.One thing you may want to look at is Bill Heath's (Turbomaster) boost controllers. With your box you can adjust boost levels to about 34#'s which is real sweet.<br>Be carefull of the bug bomb though you might end up going the route I did and end up with the HX/14 anyway. <br>Tim<br>check this out on ebay<br>http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
Old 04-13-2003 | 08:33 AM
hellotbone's Avatar
I hear the scotty 2 works pretty good I have heard it sucks.................COOOOOOOOOOOOOOLLLLLL air that is ;D
Old 04-13-2003 | 12:13 PM
Push Rod's Avatar
[quote author=tlea link=board=7;threadid=13539;start=0#127559 date=1050235928]<br>With your auto you should have the HY35, not the HX35.[/quote]<br><br>Ack, I missed the automatic there. You're over the power point where the HY35 is running efficiently, however an air system of some sort, along with either the TurboMaster or a turnbuckle/J-hook to hold the wastegate shut should keep your EGTs in check without requiring the swap to an HX35 turbo.<br><br>Rod
Old 04-13-2003 | 12:59 PM
Scotty's Avatar
Top's Younger Twin
[quote author=Push Rod link=board=7;threadid=13539;start=0#127600 date=1050250384]<br>[quote author=tlea link=board=7;threadid=13539;start=0#127559 date=1050235928]<br>With your auto you should have the HY35, not the HX35.[/quote]<br><br>Ack, I missed the automatic there. You're over the power point where the HY35 is running efficiently, however an air system of some sort, along with either the TurboMaster or a turnbuckle/J-hook to hold the wastegate shut should keep your EGTs in check without requiring the swap to an HX35 turbo.<br><br>Rod<br>[/quote]<br><br>Rod, take the wool outta yer eyes.
Old 04-13-2003 | 07:34 PM
jrs's Avatar
jrs
Thanks for the replies. I think I will go with the turbomaster to begin with and if things get too hot look to a turbo upgrade. Easier on the funds. I'm trying to medicate the bug.
NJTman
07-05-2012 12:55 AM
airforce27
11-27-2008 04:02 PM
Ada381
02-10-2008 08:58 AM
LilBigd02
02-28-2007 09:31 PM
12valve
14
02-22-2007 10:07 PM
