Will a Holley Blue work with an intank pump??
Ok so heres my questions, I have the Intank Relocation kit in my truck. I just ordered a Holley blue pump for it, without thinking. However the pump as you know will go on the frame between the engine and the fuel tank (where the stock pump is located) Is this going to work?? Or am I going to burn out the stock pump on by drawing too much with the Holley? Would it be better to just remove the intank and just run the holley??
Yep it will work. I'm seeing about 23 psi at idle but I dont know at wot because I need a new sender from quadzilla . The way I did it is just bottleneck it. Cut the steel line and run a 3/8 hose over the steel line and double clamp it and run the hose to the blue and then run a 1/2 inch line (if you want to) up to the fuel filter housing. I got the hose and fittings from Eric at Vulcan Performance. Hope this helps ya..
AlCorr
114
02-11-2009 02:32 AM
Tiara3100
15
01-10-2008 05:46 PM
Texaschevelle
26
11-16-2007 08:08 PM
Beeram305
28
08-31-2006 11:45 AM
pizzaboy
08-03-2006 07:17 AM
