Will 370 injectors give me lower RPM torque ?
I have a # 10 plate but low rpm torque is not the best in my truck, it REALLY wakes up at 1800 and up, but I want lower rpm torque.
If I remove the plate and add 370hp injectors will they give me better results ?
I tow a lot and the lower end is what I use mostly.
now whats the timing at in this truck? if its stock, ur governer arm is outta whack. If you dont wanna adjust it, move the plate back till u know that it is not diving under the plate.. The arm (with teh solenoid pulled up) should hit the tip of the plate and slide a little bit upwards...
Rick
Ok, I'm a little late here. Where do i find the governor adjustment instructions, I searched the forum but cannot find the thread.
When I look down the AAFC housing I see my plate but I don't have enough room to see the gov arm.
Go to Piers Diesel Research http://www.piersdiesel.com/TechLeverAdj.htm
Moules
04-19-2009 08:36 AM
fishin fever
02-22-2004 09:32 PM
PapaSmurf
12-19-2003 03:14 PM
JCamper
05-15-2003 10:30 PM
