Will 181dv's heat up?
First off what are the stock dv's in a 180 pump? And what would be a good upgrade, and will the be hotter egt wise for towing. Thanks
180 pump has 181 dv's!
some ppl do like the 191 as a upgrade from 181's, all i know i cut myself a set almost full cuts, they where way too smokey, lot more fuel!
You have 181's. I went from 181's to 191's in my truck, and the 191's get quite a bit hotter at Wide Open Throttle, but they are still very controllable if you know how to keep your foot out of it.
Eric
Eric
tswcoaltrain
11-12-2019 09:11 PM
