Wildcat Fuel Line Installation Part One
Got part one done of the Wildcat fuel line install thats the bottom of the cannister to the Inlet of the VP44. What I noticed is the instructions are very clean on this part (wink,wink ROD) and went very easily!
It took a little longer then anticipated because I did not cut one of the lines perfectly straight and had a leak but was solded with a quick cut to straighten things out.
What I noticed is 1 PSI increase in FP at idle the system takes longer to loose FP under WOT and recovers quite well. The system also has a 1 PSI higer cruise pressure. Keep in mind this is only stage 1 and I still have to finish the other parts.
Top's Younger Twin
Re:Wildcat Fuel Line Installation Part One
[quote author=Jamie Attridge link=board=7;threadid=17667;start=0#msg165243 date=1059495520]
[/quote]
I'd venture a guess that the 'wink wink' is intended as a jab at me. ;D No matter what Rod says...its all his fault the install destructions were so so...LOL
At least its a system that works. I was so dang mad at another one that I just had to design this. Did you notice how the fittings maintain the inner diamater too?
[/quote]
Yes scotty its a sweet kit and works! I would like some pics of the rest of the install before I start it (JAB) because I don't really know what Im replacing! I have the written from Rod but a pic is worth a 1000 words!
DarrellB
10-09-2003 07:49 PM
Jack Thorpe
Site News
10-05-2003 01:17 PM
hellotbone
08-03-2003 08:15 PM
PapaSmurf
48
07-10-2003 11:06 PM
hellotbone
07-10-2003 07:07 AM
