Wierd Twins question??
I am using my HX35 as the top turbo in my twins setup and I am getting an exhaust leak out of the center section of the HX35. It is leaking where the exhaust housing goes onto the center section. The bolts that hold the little plates that holds the exhaust housing onto the center section are tight and I had it apart right there and did not see any type of replaceable gasket???? Any ways the only reason I know that is leaking is cause it gets black in that area and is starting to turn the inside of my hood black right above it. Anyone have this problem or any ideas how to fix it? Thanks Lowell
i dont know but i remember when i got my new killer B2 turbo, it had red silicon on the under the wastegate plate (like a gasket)... red heat resistant silicon might work... just cause i saw a new turbo have that!
The big charger hanging on the smaller one, might have caused the leak...
do you have a big charger support bracket?
dodgediesel
17
04-05-2011 11:21 AM
Stock 02
28
09-24-2006 11:09 AM
stlsparky
11-21-2005 10:02 PM
