Widcat Max flow
Widcat Max flow
The long awaited Max flow kit arrived today, but no directions, I tried calling wildcat, but nobody answered, anybody out there know how to get to the directions, Rod said there would be a link to the website but there is nothing on or in the box ????????
After installing the system, I threw away the web address. Just email ron, he will give you the site again. PS some of the pictures never downloaded for me. Most of the install is kinda self taught. You will need a grinder to cut the blasted braided hose.
James
James
There's a link to my writeup of the max-flow install here:
http://www.turbodieselregistry.com/f...light=max+flow
I think you might be talking about the fitting that has a threaded hole in it and if you are, it is already tapped for 1/8" npt (national pipe thread). I have the same system on my 99 which has a different fuel filter housing than your 02. Therefore, I used one of the 1/8"npt plugs that came out of the top of my fuel filter test ports. You can see a pic of my 99 set-up by clicking HERE
We also have an install article on our site. CLICK HERE
If you don't have a fuel pressure gauge to hook up yet or don't have an 1/8"npt plug,,,,,,,, can you use the schrader valve out of the banjo fitting that you did away with? Isn't that 1/8"npt threads? I'm not sure because I didn't have one.
Hope maybe this helps.
My test port/banjo was on piece design, spent half the night serching the local part stores for the correct fitting.have to start again this morning
I thought an update would be good here since RATTLINRAM brought up the review article I wrote for the DTR some time ago.
Pressures are still the same and on the same lift pump. Pretty good for a stock lift pump considering the truck dyno's at 500hp and turns the 1/4 in 13.8 seconds.
Top's Younger Twin
Sorry about the max flow missing the instructions link.
No excuses. I forgot to double check your order.
As for the missing pictures, I sent those to Rod many times for upload. dunno what happened after that.
Scotty
http://www.wildcatdiesel.com/wildcat...uel_system.htm
Scotty
IT'S ALIVE !..........
Thought ya dropped off the planet or had started driving a Ford! ,,,,,,,,, Just kidding,,,,,,,,,
I would have figured that you would have went to one of the other fueling methods, but it sounds like you don't have the need for anything else yet. That's impressive! When I installed mine, I couldn't help but think that the Max Flow would allow the lift pumps to last longer due to less restriction. I replaced the original lift pump on mine at around 45k because it was down to about 7psi @ idle with no mods. The Max Flow went on right after the new lift pump and then I added an EZ. It still idles at 16psi and has never dropped below 12psi, even when pulling the 5er. She's going on 86k now.
I'd walk before I drove a F***.
I check in from time to time. Two kids keeps us busy which leaves no time for racing. Truck now has 135,000 miles and the motor has never been worked on.
At 500hp I probably should have a higher flow system, but if it isn't broke I'm not going to fix it.
update
Thanks to all for responding, new lift pump, and max flow complete. I even got to hook my boss hoss module back up, all seems to be running ok, next priority is fuel pressure gauge and maybe a bhaf. thanks to all
ralphyboy
01-17-2008 08:35 PM
8mpg
05-22-2006 01:35 PM
HOHN
23
12-13-2004 10:33 AM
Palmetto_kid
11-10-2003 11:22 AM
