why not the hx40
Old 12-22-2005 | 11:09 AM
HOHN's Avatar
Originally Posted by getblown5.9
so if pick up a piers modified hx40 it will have a stronger shaft that shouldnt break.
i can pick up a used piers 40 for like $600, and make about 420 hp with lower EGT's or i can keep saving and wait to go all out with a PS62
Piers' shafts aren't any bigger than stock. I personally know of a local 12Ver who popped TWO of Piers' 40s. He's ~500hp.
It's not Piers' fault. You can only polish a turd so much.
That said, a 40 can easily be made to live. Just limit it to 35psi or so. NEVER go past 38psi. Remember, the 40 and 35 share the same shaft size, but the 40 has larger wheels. Those larger wheels can make more stress on the shaft.
40s seem to last forever in twins. They only pop as singles. This is because what kills 40s are the quick transitions. Twins slow down the transitions (slower spool and let down), so your barking with a tight TC and other misbehavior is a lot less.
Another way to help a 40 live is use the 18 housing instead of the 16. The slower spool and lower boost overall helps a lot. Yes, it's a lag pig with a tight TC, but you could probably get away with it on a 6-speed. I wouldn't run it on a 5-speed because the lag will kill you on the huge 2-3 gearsplit.
If you can get a Super 40 for $750, you might want to consider it. It CAN be made to live, you just have to know and respect it limitations. Unfortunately, it just can't handle big PRs as well as a BW-Schwitzer based unit like the HTT turbos or II turbos.
For me, though, a Phat Shaft 62 is only ~$1100, and I'd rather spend a little more money for a near-bulletproof unit.
jmo
Old 12-22-2005 | 11:10 AM
Koa Man's Avatar
The PDR HX40/16 that I have on my truck works pretty good. The low end response of the whole truck became extremely strong after I put in the mad ecm. I lucked out and got the unused PDR HX40 for only $500 plus shipping from a TDR member who bought it, then decided to put in twins instead.
Old 12-22-2005 | 11:13 AM
Big Deezul's Avatar
man I need a deal like that
I thought the PS2 was around $1400?
Old 12-22-2005 | 11:55 AM
Ph4tty's Avatar
There's a B-1-2 in the classifieds for $900
Might work good for you.
As far as I can tell, the prices went up on the Phat Shafts. 62 and 64 higher than last month on II's webpage. $1400 for PS62. Guess they're selling too many
Old 12-22-2005 | 11:59 AM
HOHN's Avatar
Yikes, that Super 40 is looking better all the time, lol.
Old 12-22-2005 | 12:10 PM
White00's Avatar
What are the major differances between the PDR40 and the Super 40?? Or, are they just a similar unit made by two different companies?
Old 12-22-2005 | 12:27 PM
Big Deezul's Avatar
I saw it...non waste gated though. I think I want to make sure I stay at 40 psi or under...I dont want to do head studs
Old 12-22-2005 | 12:28 PM
Big Deezul's Avatar
I think they are differnt companies version withthe same idea in mind
Old 12-22-2005 | 12:31 PM
HOHN's Avatar
Super 40 is a "factory hot rod" from Holset, the original maker of the turbo.
PDR40 is a speed-shop reworking of the original Holset HX40.
Old 12-22-2005 | 12:32 PM
SuperDave4x4's Avatar
Originally Posted by BigBlue
Screw the 40. Go full b-1. The 40's are good little turbos if piers modifys them. If they don't they can break shafts real easily. I'm enjoying my KSB-1. Bigger than the 40, just as fast spool up as my HY35, 1150-1200* EGT's at 371hp at 40psi.
Yeah, but I think he's looking for something cheaper than the B-1 and KSB-1. I personally am going to run a S300g because for the fact that is only 700 bucks and can support 450hp easily.
Old 12-22-2005 | 01:11 PM
getblown5.9's Avatar
i drive like a maniac, i drive fast, shift fast, and love to get it spooled and hold on, i will break a 40 in a week if this is the case...time to save for that PS62...maybe 64 if i go with mach4's
Old 12-22-2005 | 06:27 PM
Big Deezul's Avatar
Sent you a pm....I think I am going your route
Old 12-23-2005 | 05:57 AM
Ph4tty's Avatar
I like the new avatar/sig Hohn.
I have a fever! And the only cure is more cowbell!
Old 12-23-2005 | 06:00 AM
Ph4tty's Avatar
Isn't that the turbo that the B-1, HTB2, and PS's are based on?
Old 12-23-2005 | 07:05 AM
Big Deezul's Avatar
not sure about the B1 but it is the turbo the PA and HTB's are based off of
ktmrdr85
50
12-21-2016 12:30 AM
freight train
05-28-2010 03:37 PM
sgrooms
21
04-08-2008 12:17 PM
SPEED FREAK
05-03-2004 05:22 PM
Hawkeye
09-23-2003 09:22 PM
