Why doesn't "Banks" do/sell injectors
#31
I hope your kidding
You cant have a 12 valve that makes good power with NO smoke. Period. A 3rd Gen is much easier, but in order to make a 12 valve spool a big turbo it has to have some fuel down low. Mine clears up almost completely after it spools but it will lay it out thick until then, and thats stock turbo. You can limit the fuel a lot on the bottom, but the turbo wont spool as fast. You just have to drive around it.
Eric
Eric
#33
To put out enough volume, those electric turbos will probably eat half of the extra horses and require an alternator the size of a PTO generator box... I've seen a cartoon of a bulky man pouring sweat, turning a generator handle to power an electric fan blowing air to cool himself down. Kind of reminds me of that.
-P
-P
#35
If I can express my own opinion. BANK$ has been progressive in the Diesel adder market, especially really early on with the 1st genners with the 14cm housing that was very rare at the time also the intercoolers replacements were the only option other than OEM... But... BUT, the prices typically were Trump style for what you got. Now that the ocean is full of products and services its too easy to source out your own stuff for much less. AGain I don't need more knocks on my reputation, IMHO
#36
#38
I just got out of a corporate meeting at Gale Banks Industries, they are coming out with some new injectors, they are good for 300 additional hp and come with a secondary electric twin turbo system to clean up the smoke. That's right, 300 ponies with no smoke. Kit will retail for $5K. And replacement electric motors will sell for 50 bucks a piece.
#39
Hey don't bash the nitro, it works great, you should try it, I thought that one up all by myself. Don't do it if you plan on keeping the same truck for 500K miles though, oil report said disaster is brewing, it was bad for the rings... is that where all the chrome came from??
#41
#42
I'm a fan of the cleaner stuff. But with a VP truck, you don't have the control over the injection even to get large quantities of fuel in without smoke. HPCR trucks have a LOT more control over the event, and can be smokeless at much higher power levels.
That said, I can drive my truck pretty cleanly without too much effort. I've noticed that once I get into it enough to make smoke, that more fuel just makes more smoke-- no more power.
Hence, the smoke is just for the "james bond" factor, not necessarily a byproduct of making more power.
I'm guessing that the future addition of a TST box might make it a little smokier-- but it should be just as manageable.
Justin
#43
king5335
03-23-2008 11:43 AM
