Why a boost gauge?
Why a boost gauge?
Some of the gauges have obvious safety/functionality purposes, but what about the boost gauge?
Is it just an interesting piece of data? or is there actually useful data that it will provide you that you can do something with (change or ease up on the throttle to maximize efficiency, etc.)
With limited amount of gauge real estate (3 in the pillar), that's the one that seems expendable. Pyro, Trans/Diff temps, and Fuel pressure seem to be the critical items to monitor.
Well if you are after top performance, it will tell you if maybe you have a boost leak, or if you have a wastegate problem or need help adjusting your wastegate properly, also after adding more fuel with mods it'll tell you whether or not you are operating in the parameters of the turbo you have or if you need a bigger turbo.
Originally Posted by y2kram
.... but what about the boost gauge? Is it just an interesting piece of data? or is there actually useful data that it will provide you that you can do something with
But your signature looks like you have done a lot of preparation for adding fuel/HP...No?
If so, I'd be more inclined to give up my Tranny Temp gauge first. After looking at it for 3 yrs...I've never needed it ..... other than Dallas gridlock on a 100* day (got to 200*) or backing a trailer up a long driveway (250*). Now I just go to neutral and a fast idle to keep things cool if stuck in bumper to bumper!
This assumes you have a full rebuilt Suncoast tranny.
RJ
RJ
RJ
Priority to me right now are gauges and then address the fuel system (pump and line kit). Have 150,000 mi. on it and haven't had any engine problems but have replaced normal stuff like alternator & starter.
I did lose 2nd gear a couple years ago which is why I had the tranny rebuilt using Suncoast.
Originally Posted by NOSPIN4ME
You don't have to stop with 3 on the a-pillar either...
Dyno #'s seem very low? Must be the stock turbo?....can't even picture an HY-35 with all that fuel
RJ
By itself, the boost guage doesn't really tell you that much. But when combined with egt, rpm, and throttle setting, it says volumes about what is happening with the engine performance.
If you're going to throw out any guage, make it the fuel pressure. Sooner or later, you'll realize that fuel pressure just isn't a big enough factor in vp44 failures to be constantly monitoring it. Occasionally taking a pressure reading at the test port on the pump, itself, is all that's necessary.
Doug, Nice looking setup! Can't see what's mounted in the Rod Pod??
RJ
RJ
That pod you mention is a Scotty piece. There's more in there now...TC lock up switch is what you see in the pick, with a couple of LEDs.
hey nospin4me, can you list all of your guages are? i can't read them, i tried your gallery and i still can't read them, and i'm sooo curious as to what all those guages could be saying!
thanks.
thanks.
Originally Posted by CumminsRedneck
is it possible, or worth running a trans temp gauge on the 6 spd manual or not
