who makes the better lift kit?
Originally posted by gaRam
i've heard of some bad things so far though. like brake lines not being long enough and breaking when the axle articulates. track bar wearing out really fast, poor ride quality, steering knuckles wearing really quick too. seems to be too much trouble unless you spend alot of money to do it all right the first time. i would love to have a 5 inch lift but don't want to wear out other parts faster because of it. but i like to look at other trucks like mine with the lifts on them, look really good. anyone with a lift on your truck, how does it do off pavement?
I have ~145K miles on my lift, and I recently replaced the original ball joints and tie rod ends at 190K miles. Your mileage may vary.
Off road, it works well for what it is set up for, which is relatively low speed. If I wanted to go fast, I'd do the T-Rex kit or better yet, build a Class 7 desert truck. I had one of those, I sold it to buy my Dodge.
Muted User
i checked rocky mountain susp. again, the 2500 5" is $640. it includes a pitman arm. the pictures show a taller block and an add-a-leaf. does anyone know how long the leaf is? i already have a tuff country 2" add-a-leaf. if i kept that would it be a little higher? instead of using the one with the kit? i want the back to have a little more stance than the front.
"The front DS problem varies from truck to truck.
You won't really know until you put the lift on.
You have the vaccum disconnect, so your shaft isn't spinning all the time like mine is, hence the highway vibe."-phox mulder
what do you mean by this? is it something that changes from year to year, the vaccum disconnect? i don't really understand. my front driveshaft isn't spinning like yours does all the time, only when i put it in 4wd? could someone please explain some of this for me. thanks
I replaced the trac bar and steering stabilizer with SJ stuff as well, which was in addition to the kit. I will most likely be needing ball joints soon (will be going with Moog), and plan on doing that when I overhaul the brakes.
FWIW - the ride I have now is no comparison to stock off of the lot, and I won't be going back.
Matt
Matt
you shift the transfer case into 4HI or 4LOW and it starts turning the front driveshaft and activiates this sleeve thus giving power to the front wheels.
Post 2002.5 doesn't have the sleeve, the axles are connected to the front driveshaft all the time, therefore the front driveshaft is always turning.
Shifting into 4HI or 4LOW just gives power to the front driveshaft, thus giving power to the front wheels.
phox
thanks for all the information, cowhand. what steering components would you recommend replacing that aren't included in the lift?
You also need to shim the center support bearing (rear driveline) down ~1/2" to eliminate any rear driveline vibration. SJ didn't supply a shim with my kit.
Matt
Matt
huh?
Wrong!
Not sure how you figure this but who buys a full size Cummins 4x4 to climb rocks...
Doesn't ruin the ride or the handling...
I didn't buy my truck and drop the kind of $ we do to worry about resale. I guarrantee engine mods are more of a deterent to good resale than a lift... oh yeah just do the transfer case index ring and spend the money on the Tom Woods shaft.
See above response. I would say the same thing about engine mods.... who cares? I am my own warranty station!
I hope you know what you're getting into with a "lift kit". You're going to end up spending money on something that will limit your suspension travel
ruin the ride and handling
kill resale
and ruin the design of your suspension that the OEM spent a lot of hours designing.
skyjacker 4.5 clears my 9.00r16 xzl's (measure almost 37" on the truck) no prob never rubbed not once... 8 inch wheels only prob is trailing arms are to short and to much of an angle, that makes the ride harsh when you hit sharp bumps in the road. I would try the superlift long arm system same price, should ride better
Originally posted by Cowhand
My suspension travel, as well as articulation, is about 4" more than stock. It rides just as crappy now (empty) as it ever did when it was stock. It handles better now because I replaced all of the carefully designed OEM steering components. Following that logic, I guess putting in an aftermarket transmission will kill my resale value because the OEM spent a lot of time designing the original trans/TC. I got news for ya, the SJ springs that you put on your truck have altered the design of your suspension that the OEM spent a lot of hours designing
No 3/16" plate in mine. I guess some kits are engineered better than others.
I didn't NEED to go higher. I didn't NEED 37" Swampers. I don't NEED 400+HP. I don't NEED 1000+ ft/lbs. But I got it.
IIRC, the Cepek kit turns your carefully designed 4-link suspension and turns it into a 2 link suspension, i.e., radius arms.
My opinion, which isn't worth more than anyone elses, is the hot set up would be what I described above, the DT stuff, custom coils, and Bilstiens.
DT makes good stuff-- I have their track bar and love it.
Cowhand, are you trying to tell us that your truck has BETTER handling after you've lifted the CG at least 4"?? I'm I the only who things that's impossible to do? Maybe we have different meaning of handling? I think of it has cornering and steering-- traction and stability.
I have news for you: the SJ springs I installed do not lift the front end any more than the OEM SnowPlow springs would have. I wanted longer, not just stiffer coils. So my truck is perfectly within OEM parameters.
The point needs to be made: if you plan on lifting your truck because you want to run large (over 35") tires, you need to be VERY sure that this is what you want, as there's a steep penalty to be paid in ride comfort, component wear, and practicality.
JLH
Originally posted by HOHN
The only problem with the "hot" setup you describe is that you can't just buy Bilstein 7100/9100 shocks. You have have to have them specially valved and setup for your application. They are NOT for the average guy, and they are NOT cheap. Bilstein basically builds these to order for Baja race teams who spec their own valving. By the time you get your valving set up, you've already spent more than the T-rex/Bilstein kit.
JLH
JLH
As far as handling, we're talking about a 3/4 ton 4X4 that weighs in the neighborhood of 8K lbs. Yes, I raised the CG better than 8", but I also increased the track 6-8". Cornering and steering? I don't throw the truck into a hard right hand curve at 65 MPH. I wouldn't do that with a stock truck. If I wanted to go fast through the twisties, I'd have bought a sports car. Traction and stability? It was a lot easier to break loose the rears when I had 265's on it. Even with the lift, the truck is more stable than your average stock Ford Explorer or any other little SUV for that matter.
And if OEM design parameters are so important, why did you go with the SJ springs instead of the factory snow plow springs? News Flash: the SJ springs have a higher spring rate than the factory springs. Is a higher spring rate within factory spec's? Not exactly. Typically, to improve handling you go with a softer spring and a more aggressive shock to control it. A stiffer spring simply results in a harsher ride. So I wouldn't say perfectly within OEM parameters, but you can believe whatever you want.
And your point that needs to be made: If I wasn't sure of what I wanted, I wouldn't have spent in upwards of $2K for my suspension. My truck probably rides better than yours does, because I ditched the POS SJ springs and shocks and went to something that provides better ride quality and handling. Practicality? Well, my truck is pretty practical for what I use it for, which is driving back and forth to work, hauling stuff in the back, tearing up the weeds on the weekend, and occasionally pulling a two horse slant. My front end components lasted 180K miles, 130K of which were after the lift was installed. That's longer than a lot of folks here get out of their components on a stock truck.
So your point isn't very sharp. Where's the steep penalty?
Muted User
very interesting. also i bought my truck with a 2" leveling kit and 35's. so i really don't know what a"stock" truck handles like. i'm used to what i got. but my question is this, is the tough country kit good? and what otrher components should be upgraded not included in the kit? please no abreviations, i'm a semi-newbie trying to learn the terms. also brake lines will be ok?
So what about the Kelderman system. Cant you use it to lift your truck and wouldnt air bags ride better? We are talking about a bunch of brands here so I thought I would throw Kelderman into the mix and try and get some feedback to see how it compares.
