Who has Mach 4 injecors??
The only smoke you should have is the intial spool-up haze depending how far you put your foot into it. Your box setting also will increase or decrease your smoke levels. Whats the maximum boost you have seen for far? Your turbo should clean-up the haze as you should be in the 50psi area, I'm guessing. It would be interesting to see how high your egt's get while empty or loaded. Elevation has some impact here as well. If your at sea level your smoke output level is less than if you live in the mountains.
Max boost 50+ psi guage only goes to 50.
It does clean up nice when its at 40-50 psi and the egts are 1100-1250 range
So is the turbo housing to big. 14 cm
70 mph 2-6 psi boost and 550-600 egts
Durning normal driving I think my truck smokes more with the tst off then with the tst in the lower settings. Even in the higher settings the truck runs pretty clean. I've heard the mach 4's don't smoke much more then the 1.5's
Randy
Randy
Randy
Randy
So can you guys take off with NO smoke??
I did a little run today. driving light pedel.
Just injectors 0-55mph it took 1 minute 15 seconds 2-3psi boost
injectors and comp on 1x1 0-55 1 minute 3 seconds 2-3 psi boost
same amout of smoke.
I just want to know if mach owners have a hase, smoke, or no smoke on take off????????
I can drive my truck with no smoke pretty easily. I just turn my drag comp off and drive easy. Even when im on the throttle hard with the box off it doesn't smoke much at all.
The Guru
Yeah its kool ride. It better than a new ride and alot faster. Mine looks similar to your ride except its has the sport package. I'm dieing to try the race track and a dyno event. There too much work going on here to stop and do something different. I guessing that its a mid to low 12 second ride at sea level. This is my fastest ride yet. You get spoiled driving it as it likes to be abused. You can pass someone at 70mph and hit around high 90's by the time your finished passing. Hey your still running the orginal tires, cool. I'm just finishing off my second set. I dont' do burnouts out too often. I'm get old
Randy
Thanks, there stock 3rd gen wheels & tires (polished not chrome clad). Bought them on e-bay. $650 for the set, it was cheaper then when I replace the original michelins
